Need Help!! with welds
If you are looking for a wheel wider than a 15 X 8 but can't fit a 15 X 10, why not try a 15 X 9?
A 15 X 9 with a 6.5 B/S should fit. I am running a 15 X 10 with a 6.5 B/S on my car right now. Granted, I don't have tailpipes, but I don't have any problems with my 28 x 10.5 M/T's rubbing.
I guess I'm out of ideas then. You said in your first post that you tried a 15 x 8 with a 6.5 B/S and the tire was "too close for comfort near the pipes". Then you said that a 15 X 8 with a 5.5 B/S was "to close to the fender lip". I guess the only thing left is either deal with the tire rubbing somewhere, or going with a 15 X 7 with either a 6.5 B/S or a 5.5 B/S.
The only other thing I could think of is order a set of wheels from someone like Bogart that can make you any size rim you want with any size B/S. Only problem with that is their rims aren't made to be driven on the street and I am assuming that this is for a street car.
i'm gonna try a 15 x 9 with a 6.50 back spacing the guy at the wheel shop has the same setu; on his coupe and it only rubs when you hit a speed bump to fast, but he also has eibach drag launch springs,
ASKED TO BE BANNED
ASKED TO BE BANNED
well bolted up a set of 15 x 8 with a 6.50 back spacing, and had 265 50 15 tires and no rub, but i'm goin a different direction, but thanks for all the info, i let my buddy know cuz he just did the lincoln swap, i'm doing 17 chrome ponys with eiback sportlines
ASKED TO BE BANNED
ASKED TO BE BANNED
