so i got the the new motor started tonight...
i finally got the motor in and cranked up,about 3minutes into it the headers started to glowing red they got so hot.is this normal?they art brand new ceramic coated headers.i had to shut it down after 10 minutes i was starting to get worried.oil presure kicked in fine,and held steady presure.temp was also good.
2nd question...i have the black morroso double sump oil pan,how much oil is it supposed to take.
Originally Posted by stockstang
dont know that its normal for your headers to glow when at idle. Were they glowing at idle, if so what are you idleing at? Oil pan is most likely a 7 quart sump.
Originally Posted by Mars_302
you running a carb or efi? You dialed in the timing yet? Timing is off, it will make the headers glow red.
SC Motorsports
11801 State Road 52
Hudson, FL 34669-3092
(727) 856-8768
FordSpeed Racing
11733 66th St., Unit 123
Largo, FL 33773
(727) 549-8255
Dynojet Chassis Dyno
SC Motorsports
11801 State Road 52
(727) 856-8768
FordSpeed Racing
Largo, FL 33773
(727) 549-8255
it is a 7 quart pan, and they are both correct, too much fuel cause the headers to glow by burning the excess fuel in the header itself, or too lean can cause them to glow by having the exhaust temp too high
chad
chad
www.racinginnovationsfl.com
www.xsrcylinderheads.com
4.842@156 and 7.53@192 on radials
