Looking for a motor
With gas I just worry about the fuel consumption. It takes 35 hp and 3600 rpms to make the power and speed to generate 120volt @ 60 Hz. A 2.3 will use alot of fuel at those rpms. If I put a 55 gallon drum next to the motor I want that to last for a few days.
Guest
Posts: n/a
If you only need 35 hp, honestly, I'd get an air cooled VW motor. It will run as long as there is gas in it, most come with a generator instead of alternator (sucks for a car, great for a simple stationary motor), they sip barely any fuel (single carb with a 28mm venturi) and are air cooled so no radiator or hoses to worry about. Plus you can get one cheap.
