Anyone want to install hg?
Old May 27, 2005 | 05:15 AM
  #21 (permalink)
TheShow50h's Avatar
The little 5.0 that could
Originally Posted by racingtheburg
The studs are a safer way to go.....And as for a head gasket I am recomending him somthing reusable just incase we find something else wrong and then he has 50-70 bucks down the drain because he didnt get good gaskets.
Joe I will try to find you some today ..
Damn... the gaskets I been using are 120+.. I just got some regular felpro's on now though.
-Vince
Old May 27, 2005 | 05:25 AM
  #22 (permalink)
Stangonline's Avatar
Studs are "supposed" to be better... They are a little more complicated to get setup right, so its easy to make a mistake that will have you redoing it again. Personally, I think bolts are fine for most applications. Last time I used studs in a fox body, it made it a PITA to get the heads on and off too.
Jeff
Jeff
93 Coupe - check out my blog - http://www.93coupe.com
01 Cobra - Stockified - Wife Owned and operated
68 Coupe PROJECT <- Been in the family for 25 years!
Old May 27, 2005 | 06:02 AM
  #23 (permalink)
Flastangs's Avatar
What do you guys torgue your bolts on alum heads to? I have heard everything from 45 lbd to 90-100 lbs.
Old May 27, 2005 | 07:32 AM
  #24 (permalink)
Steve B's Avatar
brings his heater.
its done in steps, the gaskets will have torque load instructions
Old May 27, 2005 | 07:40 AM
  #25 (permalink)
TheShow50h's Avatar
How much are you paying to get this hg install done?
-Vince
Old May 27, 2005 | 10:14 AM
  #26 (permalink)
Steve B's Avatar
brings his heater.
+1 for studs, i have never blown a headgasket with studs.
Old May 27, 2005 | 10:57 AM
  #27 (permalink)
Flastangs's Avatar
not sure yet..maybe some $$ and beer..after of course.
Old May 27, 2005 | 03:38 PM
  #28 (permalink)
herrcomestrouble's Avatar
I tq mine... center out... 50ft lbs. Then Center out 75ft lbs, then finally 90ftlbs... And I put a dab of oil between the washer, and the head ( keep the nut from binding on the aluminum)...
-Cody
Sn95' Tripple Black Cobra
Mods:Heads/Cam/Intake/Exhaust...just your typical stock mustang...
Old May 27, 2005 | 04:13 PM
  #29 (permalink)
Flastangs's Avatar
thanks for the torque info.
Old May 27, 2005 | 04:45 PM
  #30 (permalink)
T/S #25's Avatar
Need To Get Quicker
I go 80lbs on the short bolts and 90lbs on the long bolts, give or take a pound or two.
Joe
FordSpeed Racing
9.78 @ 136.05
www.fordspeedracing.com
