Anyone want to install hg?
Make sure you Clean out the threads in the block for the HeadBolts!!! and use some never sieze on the bolts... What kind of heads do you have? If they are aluminum you have to use a copper ring gasket also...
Sn95' Tripple Black Cobra
Mods:Heads/Cam/Intake/Exhaust...just your typical stock mustang...
Originally Posted by Flastangs
Any of you 5.0 backyard mechanics want to install a set of headgaskets on a 302 this sat? If so how much? I should have it torn down to the block by then.
-Vince
-Vince
Ewwww. head studs. estimate just went up
Any reason for the studs? Honestly, they are even more difficult to get right than normal bolts. Plus, urban legend is that if you are using a stock block, studs can actually distort the deck... ?? Dont know about that one - but put it this way. My next project plan is about 600hp and Im going to use arp bolts, not studs.
Jeff
93 Coupe - check out my blog - http://www.93coupe.com
01 Cobra - Stockified - Wife Owned and operated
68 Coupe PROJECT <- Been in the family for 25 years!
Jeff
Use ARP thread sealer and ARP assembly lube or oil on the head studs, not anti-seize.
The studs are a safer way to go.....And as for a head gasket I am recomending him somthing reusable just incase we find something else wrong and then he has 50-70 bucks down the drain because he didnt get good gaskets.
Joe I will try to find you some today ..
thats what i get for not paying attention
