Finally found a fastback.
Old May 30, 2005 | 03:18 AM
  #51 (permalink)
Flastangs's Avatar
Originally Posted by Strokd85
newer suspension components (not sure which way I'm going yet, still researching), possibly going to go with a turbo'd 351, shooting for 600rwhp or close to it.. wouldn't mind a KB blown setup either if I went fuel injected with it, the whine would be nasty coming from the car...should be fun to play with.. either a viper spec t-56 or a tko-600, going to keep the look of the car pretty stock from a body standpoint, just a lower stance and probably 17" or 18" wheels (maybe 18"s in the rear 17" up front.. not sure)... larger discs at all 4 corners, overall probably looking to go the way of a g-ride. for a paint color, want to go with a burnt metallic orange with more of a silver boss stripe setup vs. the black..
something along those lines..
Have you seen the issue of Hot Rod with the GT500 on it?? In it is a 69 Boss clone with a Cobra mod motor and T-45 in it...pretty kewl...also you might wanna check out this g-machine site www.Pro-Touring.com there are some cool rides on there.
Old May 30, 2005 | 04:45 AM
  #52 (permalink)
Stangonline's Avatar
Check out the attached pictures. These had me seriously considering a coupe. You might be interested in the color.
Sounds like your in the same boat as me for mods.
Thinking of a turbo 331, injected TKO-600 is almost a definate. Suspension will likely be Griggs, or TCP, or a mix of the two. Brakes - as big as I can fit behind whatever wheels I choose Wheels - probably 17s.
Im thinking of silver with black stripes following the turn signal hood, or black with silver stripes
Jeff
Jeff
93 Coupe - check out my blog - http://www.93coupe.com
01 Cobra - Stockified - Wife Owned and operated
68 Coupe PROJECT <- Been in the family for 25 years!
Old May 30, 2005 | 09:33 AM
  #54 (permalink)
Flastangs's Avatar
I would like to find a 65-66 fastback to Pro-Tour...latemodel drive train or carb 302 with big wheels (18-20 max) and upgraded suspension.
