What year engine?
Hey if you need stock TRW forged pistons and stock rods that have been checked and cleaned I have a set I can sell you, the rods will need to be pressed back on to the rods but I can do that if I need to I have a 20 ton shop press I can use. I will also throw in a set of new Hastings rings for the pistons as well as some clevite main and rod bearings, this is based on if your block does not need to be bored or the crank cut because the bearings are std/std and the rings are for a 4.00 bore. 125.00 for all of it.
Ryan
1990 Mustang GT (In Process)
1993 LX Coupe (Daily Driver, but just choose not to)
2005 Excursion (Big Pig)
Ryan
