Cooling 351W
Old May 17, 2005 | 01:46 PM
Big-D-Bo's Avatar
Sweet Lincoln's mullet
Default ?
Originally Posted by T/S #25
I'm asking a few questions only because I am just trying to figure out what kind of compression ratio you might end up with.
Yeah its cool i dont mind answering any of them, I still would like to know what brand i should go with for the waterpump? Will a 45degree waterneck be ok if i dont intend for there to be a clearence issue.
-Derek-
Old May 17, 2005 | 01:48 PM
Big-D-Bo's Avatar
Originally Posted by 351coupe
You do have a small cam,the AOD will add to the heat factor,what size are the combustion chambers on the heads?
Small cam, I figured it was the best one for the overall build of motor. Not to agressive not to mild.
-Derek-
Old May 17, 2005 | 03:01 PM
351coupe's Avatar
refinish artist
A 45 degree neck would be fine,I had a stock one and no problems.As for the waterpump,Edlebrock's aluminum one's are a very good piece.
Old May 18, 2005 | 04:30 AM
T/S #25's Avatar
Need To Get Quicker
I'm gonna guess your compression ratio is going to be somewhere close to 10.3-1. Of course, without knowing all the particulars, this is just an calculated guess.
Joe
FordSpeed Racing
9.78 @ 136.05
www.fordspeedracing.com
