Official: Turbo Project Thread.
Old May 9, 2005 | 06:28 PM
dnstommy's Avatar
Call me Chris :)
Question #1 how much power do you want to make. That determines the rest of teh answers.
Piping - Turbo cars don't have the air momentum of the supercharger cars, so to get around it they create their own velocity multiplier (down step). From the turbo to the intercooler use as big as you can fit in the car. Leaving the intercooler if you are under 20 psi use 2.5 inch tubing, over use 3.0. I would use aluminum just because its easy to fab. I will post pics tomorrow of the work we did and I can tell you have to fab nice stuff.
Fuel - Fuel is loke pussy, you can never have to much of it on hand - just use what you need. Easy calculation (horsepower * .1 = injector size @ 70% duty cycle) So if you are making 500 use 50's etc.. As for pump the externals are nice but they get hot, you can use a Barry Grant 6 volt step down or a weldon Dial-a-pump to lower the voltage to keep it cool on the street. I have a Weldon 2345 and it gets hot fast.
How much fuel do I need? You are making boost so you will up you pressure to battle the air in the engine. More pressure means less volume (always remember that). Some pumps get cut in half from 40 to 60 psi. Another calculation. ((injector size * .80 * cylinders) / 6.44 = gallons you need per hour. Multiply by 4.546 to find liters. Now find a pump that will do that @ 40 + your max boost.
(I.E. ((50 lb inj.) *.80 * 8 ) 6.44 = 46.6 gph or 211 lph. A 255 lph pump is 255 @ 35 psi. I bet its 140 @ 65.
Some calculaters show some different numbers, but mine are close.
Old May 10, 2005 | 04:08 AM
BigDawg's Avatar
has his prioritys ef'd up
Dont run aeromotive on the street, unless you are planning to run the fuel controller at least, plus the aeromotive is so god damn loud, probably louder than the spool of the turbo. It isnt cost effecient to run that pump either, they need to be rebuilt on occasions as for the GSS342L Walbro which is a pusher pump at 255 LPH is well enough to work with his application of being "street freindly".
Ryan
1990 Mustang GT (In Process)
1993 LX Coupe (Daily Driver, but just choose not to)
2005 Excursion (Big Pig)
Old May 10, 2005 | 02:12 PM
Red Baron's Avatar
"Dont let your Meat-loaf"
Naaawww That thing isnt that loud.... I've ran this sys for quite some time now and havent had a prob.. well I take that back, it has got a lot more quiet since I went carb. due to the fuel press change.. but still it wasnt any louder than my buddys T-Rex
~Baron
Old May 10, 2005 | 03:13 PM
GsEclipse02's Avatar
Originally Posted by Scott
Tial products for sure on the BOV and wastegate.
2.5inch piping.
Go to turbomustangs.com and watch their classifieds for good used stuff.
Good luck with it.
he says its to much but in the end it will be worth it .... you wont have to worry about boost spiking or somethign to that matter.... the bov you can find a cheap one on TR ive found a few good 1s for 50 bucks..... greddy type R and S also, turbo Xs RFl and hks bov so just look around dont try to be cheap you will have to just spend more money later on down the road
Old May 10, 2005 | 03:29 PM
ODB's Avatar
ODB
S.Y.L.O.
dude...correct me if I am wrong....doesn't that motor have well over 100k on it?? build the whole motor from scratch!
Old May 12, 2005 | 05:19 PM
  #17 (permalink)
dnstommy's Avatar
Call me Chris :)
Here is the tubing pic, use aluminum
Old May 13, 2005 | 11:45 AM
  #18 (permalink)
BDIX's Avatar
Dick is Huge!
yeah, scratch this whole thread... put the car up for sale...
my turbo + intercooler is for sale though
Totalled his shit!@
Old May 13, 2005 | 01:23 PM
  #20 (permalink)
BDIX's Avatar
Dick is Huge!
garrett turbo a/r 70
unknown intercooler
Totalled his shit!@
John
Jul 10, 2006 01:39 PM
fadedSTi
Subaru Tech
Feb 28, 2005 03:00 PM
Billy
TRack Events Forum
93
Apr 2, 2004 11:27 AM
John
Oct 26, 2002 04:39 PM
