engine build ????
Old Apr 11, 2005 | 04:22 PM
HELMUT RONER's Avatar
USAFR Veteran
Originally Posted by cantgetenough
Im going go get my 302 roller block machined monday.
Im going to purchase a rotating assembly from summit with forged pistons with moly rings, forged 4340 steel H beam rods, and a forged 4340 steel crank.
Im going to use the TRICK FLOW TWISTED WEDGE ALUMINUM heads.
My qusetion is will the forged flat top pistons with valve reliefs be the best way to go with this setup?
With those parts don't just get the machine machining done. Go full out race prep on the block. Make sure it get totally stress relieved. Those parts are really nice to have, but you're polishing a turd when dealing with a stock block no matter how much money you throw at it. Better make sure your tune is up to par, also.
What are your power goals with the car? What kind of driving will it see? How often? Stock stroke? Srtoker? You can use box stock Twisted Wedge heads on a stock shortblock. You have to clay the pistons if you're going to be .226 or over in duration to ensure whether or not your cam will clear. Power band will not solely depend on which cam and heads you're using, but intake as well. If you want most of the power down low a good aftermarket street intake (or dual plane if you're carbed) will do. Race intakes where they make power well above your rev limiter, like the Victor series or Track Heat intakes, will take away from your low end.
Helmut
Old Apr 11, 2005 | 04:47 PM
cantgetenough's Avatar
02 Saleen
im shooting for only 350 HP for right now but im going to supercharge it later on, im going with a stock stroke,and its going to be daily drivin....this is whats is going in... https://www.tamparacing.com/forums/s...d.php?t=223790
White Stallion.......let the horses run!!!!!
Old Apr 11, 2005 | 05:17 PM
herrcomestrouble's Avatar
If your staying stock cubes... dont expect anything close to 350rwhp....
What rollers are you planning on going with? That has alot to do with final lift and P to V clearance. And like John stated, the twisted wedge refers to the arrangment of the valves in the head. Stock valve relief pistons will be fine...
Let us know how it comes along..
Sn95' Tripple Black Cobra
Mods:Heads/Cam/Intake/Exhaust...just your typical stock mustang...
Old Apr 11, 2005 | 08:49 PM
T/S #25's Avatar
Need To Get Quicker
I just finished installing a set of TFS Twisted Wedge heads, TFS Track Heat intake and a TFS Stage 2 camshaft in a 91 LX with a stock bottom end. It ended up putting 304HP to the rear wheels which is about 360HP at the flywheel.
Needless to say there wasn't any clearance problems at all.
Joe
FordSpeed Racing
9.78 @ 136.05
www.fordspeedracing.com
Jordan Y.
Mar 26, 2004 04:48 PM
Scott
Nov 7, 2002 07:33 AM
GSRBoy
May 21, 2002 12:33 AM
