here we go again
Old Apr 2, 2005 | 02:57 PM
ODB's Avatar
ODB
S.Y.L.O.
no it looks like nuggas' r us in your pics...
Old Apr 2, 2005 | 07:29 PM
Steve B's Avatar
brings his heater.
lol its alway nuggas r us.
heres more pics.
getting ready to install
test fit, we put all bolts on loosely before tightening them.
all tightened down, view from top.
you really need an impact to get these off. thanks again big b for the compressor.
look at this crap, grind these bolts down on two sides, i hope......
one side mocked up, making sure for fit, painting the struts/spindles black. car will be pewter.
Old Apr 2, 2005 | 08:51 PM
Strokd85's Avatar
Daddy-O
Steve, you should've told me you were going to do this prior, I already had modified the bolts for the K-member. Also, you need to get rid of that rag joint in your steering shaft.. I've got the one from mine that had the universal setup on it. let me know if you want it.
I am your penalty.....
Old Apr 3, 2005 | 05:04 AM
Steve B's Avatar
brings his heater.
alot of that junk is going in the trash.......
Old Apr 3, 2005 | 06:02 AM
69Boss521's Avatar
PORK CHOP SAMICHES!!!!!
R&D is always nice...... especially when some one does it for you. What Coil overs are you using? I see your using the stock spindles.
Derp!
Old Apr 3, 2005 | 06:06 AM
Strokd85's Avatar
Daddy-O
well if you need it, i just need to un-bolt it, will save you about $50 if you go to buy it yourself.. just let me know man, you know where I live now.
Old Apr 3, 2005 | 03:36 PM
  #17 (permalink)
Steve B's Avatar
brings his heater.
ground the nuts down to bolt the k memeber in. kids wear eye protection, dont be an idiot like me.
it was really simple to bolt the shocks to the spindles(shims required), coilovers are much easier to operate than that stock stuff.
the caster camber plates bolted up with no problem.
both sides bolted up without much hassle.
time for lots of sanding....
Old Apr 3, 2005 | 03:55 PM
  #18 (permalink)
Steve B's Avatar
brings his heater.
granatelli, seems like a decent enough product., there sure arent very many pieces for the price.
Old Apr 3, 2005 | 05:33 PM
  #19 (permalink)
69Boss521's Avatar
That looked pretty easy.......... why did you have to grind the bolts? And where did you use shims?
Derp!
Old Apr 3, 2005 | 05:40 PM
  #20 (permalink)
Steve B's Avatar
brings his heater.
if you looks closely at this picture, you can see the nuts size in relation to the stud it goes on, there is a super highres pic in my gallery.
the shims are because the width of the v8 spindle, which i changed from the smaller 4cyl/pre 87 brakes (~10"). they go between the shock and the spindle.
