Tech Advice # 2
Old Mar 25, 2005 | 02:50 AM
69Boss521's Avatar
PORK CHOP SAMICHES!!!!!
Default Tech Advice # 2
I just realized my Trick Flow tall valve covers don't have a ventilation port. I am going to port the driver side, would anyone reccomend Positive Ventilation? Meaning a pvc tube going to the aircleaner or carb? Or just pop a K&N breather on it? I am afraid with the high compression it will pull oil into the line PVC line if I run one.
Derp!
Old Mar 25, 2005 | 03:10 AM
$hawn's Avatar
lives in a glass house
If you're gonna run a PCV I think you're going to need two holes.
One with a breather to let clean air in and the other smaller hole to pcv.
You will be fine w/o one but it does help with that engine oil smell if you do alot of street driving with it.
Originally Posted by cochese
Focus on getting that piece shit down the track, stop posting stories.
Old Mar 25, 2005 | 03:20 AM
69Boss521's Avatar
I was under the impression you had to have one, won't the pressure build up in the oilpan?
Derp!
Old Mar 25, 2005 | 03:34 AM
$hawn's Avatar
Yes, you have to atleast have the breather. The second hole for the PCV is optional if you choose to use it. Kinds sucks about the Trickflow covers not having holes.
Old Mar 25, 2005 | 03:44 AM
Leonard's Avatar
OUCH!!!
Just put a breather on it. PCV was designed to pull crankcase gasses into the intake and burn them so that they didn't get out into the open air. It's solely an emissions device.
Old Mar 25, 2005 | 03:47 AM
69Boss521's Avatar
damn now I have to cut on that nice paint........
Derp!
Old Mar 25, 2005 | 04:04 AM
BigDawg's Avatar
has his prioritys ef'd up
What are you going to do about an oil fill tube? Trick Flow makes a peice that you have to buy additionally to the valve covers, for an oil fill neck. You can use that as a PCV and an oil fill, personally, I would have prefered the regular FRPP valve covers IMO.
Ryan
1990 Mustang GT (In Process)
1993 LX Coupe (Daily Driver, but just choose not to)
2005 Excursion (Big Pig)
Old Mar 25, 2005 | 04:12 AM
Stangonline's Avatar
Not 100% true or there would be no such thing as evac pumps.
Jeff
93 Coupe - check out my blog - http://www.93coupe.com
01 Cobra - Stockified - Wife Owned and operated
68 Coupe PROJECT <- Been in the family for 25 years!
Old Mar 25, 2005 | 04:30 AM
69Boss521's Avatar
I looked BigD, I can't find what your talking about..... got a link?
Derp!
Old Mar 25, 2005 | 05:20 AM
TheShow50h's Avatar
The little 5.0 that could
I don't have a pcv valve.
-Vince
