11's?
Originally Posted by MiDiablo
Front:
Lakewood 90/10 Struts
UPR Chromoly K-Member
UPR Chromoly A-Arms
UPR Coilovers w/175 pound spring rate
OEM Sway Bar Removed (if not a daily driven, highway action car)
Rear:
Lakewood 50/50 Shocks
UPR Anti-Roll Bar
Eibach Drag Springs
Eibach Air Bag Drag Kit
UPR Double Adj. Upper Control Arms
UPR Single Adj. Lower Control Arms
UPR Spherical Bushings
http://www.uprproducts.com/mustang_s...v=mustang&m=MS
http://search.ebay.com/lakewood_Shoc...1QQsacatZ33590
http://eibach.com/cgi-bin/htmlos.exe...10913400006863
That'll do abso-fucking-lute wonders for the car!
Josh
UPR Chromoly A-Arms
Rear:
UPR Anti-Roll Bar
Eibach Drag Springs
Josh
yep...
(and maybe some subframe connectors)
throw some at the track weight savings into that: remove all seats except driver, remove spare and any trunk crap, skinnies up front (and he already has slicks).... so, cut a 1.5 60' and he should be very high 11s ... like 11.8x
I don't know if I'd go with a chromoly K-member if it's a street car. They may be a bit lighter but they are more brittle. I've also heard not so good things about UPR k-members. I too and looking for a K-member and have research alot. I've found out for this part is true you get what you pay for. Since this is a vital part of the car I'd go with either Griggs, MM, or AJE.
Again I still have the stock K-member and here's my suspension setup. It got me high 1.5's on motor.
90/10's
50/50's
Eibach drag springs
Chassis Engineering UCA and LCA (non adj polyurethane bushings)
Stock rear sway bar
no front sway bar.
I'm sure with a k-member I could cut low 1.5's maybe a 1.4. But if your gonna get a k-member spend the extra cash and get coil overs. You'll thank me later. -Mark
90/10's
50/50's
Eibach drag springs
Stock rear sway bar
no front sway bar.
98' cobra
98' cobra
