drag radials
Old Mar 9, 2005 | 03:13 PM
TIM TIM TIM's Avatar
could be worse
Default drag radials
I am considering a set of drag radials for my car. How will my car handle launching with them? Will it be like a honda and snap axles (not hating, they just break them alot) or will I be safe running them? I know anything is possible, But I mean is it likely to break stuff?
aim:because tim said
Old Mar 9, 2005 | 03:15 PM
TheShow50h's Avatar
The little 5.0 that could
Unlikely, but anything is possible.
If your worried about breakin stuff, you should give up racing.
-Vince
Old Mar 9, 2005 | 03:17 PM
could be worse
well when all i have is an offroad hpipe on a car with 30k miles, i dont want to break stuff If i do, then i do, but i am not gonna spend money on tires if it is likely for me to break shit, id just save it.
Old Mar 9, 2005 | 03:29 PM
GB's Avatar
GB
Great Cornholio
I've got a set of Nitto 555R's coming Tuesday, I'll let you know after I put them on. I don't think you're going to snap an axle though.
SLEEPER
Old Mar 9, 2005 | 03:32 PM
could be worse
Its that, or save and eventually just do short shifter or lower it. i cant decide
Old Mar 9, 2005 | 03:41 PM
Super Coupe's Avatar
Old school TR member
I have them on my car........They work good ......They work even better if Heat them up.......I heat them up and dump it at around 5k and I am gone They spin about once....But With my old tires I could dump it at 2k and spin through 1st and 2nd.....So traction has improved alot......Havnt broke anything yet had them on car for 3k miles.......
Old Mar 9, 2005 | 03:43 PM
stangerang's Avatar
whoopdy fucking do!
on a gt you shouldn't break anything, but once againg, anything is possible........ just use the water box, do a quick spin and you should be good to go.........
the ford rears are really tough.........
200 points away from a 300
Old Mar 9, 2005 | 03:56 PM
GB's Avatar
GB
Great Cornholio
Originally Posted by ToRqUe
I have them on my car........They work good ......They work even better if Heat them up.......I heat them up and dump it at around 5k and I am gone They spin about once....But With my old tires I could dump it at 2k and spin through 1st and 2nd.....So traction has inproved alot......Havnt broke anything yet had them on car for 3k miles.......
I can't wait to try them out. I spin through 1st and 2nd as well, sometimes when I dump it in 3rd it will break loose. No more of that crap. How much time do you think a good set of drag radials will take off a 1/4 mile run, like I said it spins through 2nd now, and I 've got to feather it out of the hole at about 2k rpms with regular tires.
SLEEPER
Old Mar 9, 2005 | 04:01 PM
Not sure on how much time u will take off your 1/4.......But ud have alot better 60's............
Old Mar 9, 2005 | 04:03 PM
mine are nitto 555r 285/ 40 /17's btw
