my terminator is shutting off..
so yesterday afternoon i installed my KN FIPK and to my knowledge hooked everythihng back the wya it is supposed to be. so after taking it for a few test runs everything is fine but later that night after going WOT it would turn off when i came to slowing down. this did not happen everytime but about 3 out of 15 times or so. no check engine lights are on so i dont have a clue. anyone got any ideas? thanks
joe
joe
im like a sore dick, ya just cant beat me!!
Might also be the TPS (Throttle Position Sensor). Mine would cut out when I was slowing down. What really sux is that when the car shuts off, you loose power steering and your brakes. Good luck.
-Ryan-
-Ryan-
sounds like the infamous stall problem some 03's had, the dealer has a new tune that should fix it but try the other ideas first
in memory of Kevin Gonzalez 6/21/86 - 9/13/06
where is this bastard of a TPS located. ill check the MAF for gunk. luckily today it hasnt done it but that doesnt say much. thanks for the help
i had a similar problem after the install of an aftermarket CAI. I had changed the position of the MAF not realizing it. Someone hinted to me to position it back to 10-12 o'clock. Never had a problem again. May not be your issue, but check to see if the MAF is positioned where it was orginally....
Bo
Bo
2008 Shelby GT500 Black Coupe
JLT CAI, MRT H-pipe, FRPP Axle back
BMR UCA,LCA's and Panhard bar (Adujustable)
532rwhp/572rwtq
2003 SVT Cobra Coupe.....SOLD
#154 of 8694
532rwhp/572rwtq
#154 of 8694
+1 on te position of the MAF alhtough I have a KNN (abhout to go pro-m) and it never had that problem before, I never oiled mine or anything though so that may be the culprit
Proud OIF/OEF Veteran and still serving
