Lifter vally girdle??
Old Feb 21, 2005 | 07:50 PM
351coupe's Avatar
refinish artist
Question Lifter vally girdle??
I remember seeing someone posting a thread about a new type of lifter valley girdle and wanted to take a look at it again.I did a search but can't find it,please help if you could provide the link.Thank you.
Old Feb 21, 2005 | 08:56 PM
SoL_93GT's Avatar
http://www.horsepowersales.net/
Red 93 GT with only 9000 original miles on it.
HP Performance Stage 1 Street kit with 60mm turbo
Car Pics
11.29 @ 126 mph 16 psi
16 lbs of boost 509 rwhp/626 rwtq
12 lbs of boost 433 rwhp/571 rwtq
********STOCK MOTOR*******
Old Feb 21, 2005 | 09:01 PM
351coupe's Avatar
refinish artist
Thanks bro.
Old Feb 22, 2005 | 09:47 AM
HELMUT RONER's Avatar
USAFR Veteran
Problem is that the 302 and 351W start splitting from in the mains. The cracking works its way up throught the center of the block's mass causing the lifter valley crack.
http://www.corral.net/forums/showthr...=valley+girdle
Helmut
Old Feb 22, 2005 | 12:22 PM
SoL_93GT's Avatar
Just for the sole reason that on their website they show a stock block cracked in half and under the caption they say "Picture above was a FORD Motorsport "A4 Block" I think they are snake oil salesmen and their product is a joke. I think the intake puts plenty of clamping force in the lifter valley area and the cracking starts in the main webbing area not the lifter valley. I don't have either on my motor and it's makine 600 at the flywheel. Theres a thread on turbomustangs.com you might have seen it Scott, it was about Tommy's car that's making like 680 rwhp with just the DSS girdle. I guess it's just luck because some block castings are slightly stronger than others, some people split their blocks at 400 rwhp and others make 650 rwhp and it works fine. I'm gonna get the prc halo type main girdle that ties into the oil pan webbing like the one BarryD is using, hopefully I'll be able to make 600-650 rwhp without a failure. Or should I say, I hope I get lucky and have one of those special blocks.
Briane
Car Pics
