Lifter vally girdle??
i believe that a cast iron intake is better than aluminum holding the block together since aluminum starts to flex which weakens the upper half of the motor, so the girdle comes into play as a band aid to hold top half from flexing but is it worth the money putting into a stock block?
Originally Posted by Scott
be careful when you are driving through the mess when it goes boom.
Briane
Red 93 GT with only 9000 original miles on it.
HP Performance Stage 1 Street kit with 60mm turbo
Car Pics
11.29 @ 126 mph 16 psi
16 lbs of boost 509 rwhp/626 rwtq
12 lbs of boost 433 rwhp/571 rwtq
********STOCK MOTOR*******
Car Pics
Guest
Posts: n/a
If you convert my 1/8th mile times on any of my runs with the automatic and low boost I had a easy 10.20 in it. To bad my converter was not what it was supposed to be.
With that said you should geta 10.20 easily the way it sits now plus the right suspension. But the suspension is going to be the hardest thing to dial in but once it is, oh mama hold on !
With that said you should geta 10.20 easily the way it sits now plus the right suspension. But the suspension is going to be the hardest thing to dial in but once it is, oh mama hold on !blah blah blah... if this... if that.... I bet you'd run a 10.10 with a tail wind too.....
You ran what you ran and it wasn't a 10.20....
LOL tough crowd. I was hoping you would have gotten your combo straightened out before you tore it apart. All always like to see how far people can go on stock parts. What do you think it will go with the new motor? I can't wait to get my suspension done, this thing is down right scary trying to harness 700 lb ft of tq through stock suspension. I deffinately think I'm gonna get an adj rear antiroll bar so it will leave sraight.
Briane
Briane
Car Pics
Car Pics
