Newbie Needs Help
Well at least you got a Mustang, you got the heaviest and slowest one ever made in GT form except your exact car with an AOD. You're not making enough power to worry about touching your suspension or brakes. You need a good shifter first off, then you need a set of 4.10 gears, thats 1/2 sec. in the 1/4 mile right there. Subframe connectors if you're gonna run sticky tires at the track. Do a tune up, with synthetics and a K&N and good plugs, take it to the track, if you have stickey tires launch it at 6000 rpm and powershift it at 6000 and you'll be surprised how fast you can make it go. The next thing I'd do is nitrous but you may not be ready for that yet and if you have the money get a good blower or turbo kit.
Good luck,
Briane
Good luck,
Briane
Red 93 GT with only 9000 original miles on it.
HP Performance Stage 1 Street kit with 60mm turbo
Car Pics
11.29 @ 126 mph 16 psi
16 lbs of boost 509 rwhp/626 rwtq
12 lbs of boost 433 rwhp/571 rwtq
********STOCK MOTOR*******
Car Pics
If it were me I'd check with dealership to see if that car ever had the intake recall service done to it. If not, I'd look into an aftermarket setup as soon as funds and/or priorities allow. The intakes were cracking and shooting coolant all over the bengine bay.
Helmut
Helmut
Joann
Apr 17, 2004 04:38 PM
