Speedo cable
Old Feb 8, 2005 | 05:13 PM
GB's Avatar
GB
Great Cornholio
Default Speedo cable
I'll be up front and say I'm not the most mechanically inclined, so if this question sounds dumb, bear with me. I pulled my car out of the garage Sunday and there was a very small stain on the floor. I looked under the car and there was a cable hitting the h-pipe. It had melted the cable to a flat spot and there was reddish fluid on the cable. First, is that the speedo cable and second is there fluid in it(I'm assuming it's some sort of lube)? The location of the cable is on the drivers side where the front panel meets the drivers door right above the h-pipe. If I drive it in the meantime until I fix it, will it mess anything up. Any suggestions?
SLEEPER
Old Feb 9, 2005 | 04:17 AM
BigDawg's Avatar
has his prioritys ef'd up
If the cable is grey, its is a speedo, if it is black then shifter cable. I would say it is safe for a little while, you will start noticing it to bounce probably, menaing you will need to get another REAL soon. but it would not do any damage as far as I know.
Ryan
1990 Mustang GT (In Process)
1993 LX Coupe (Daily Driver, but just choose not to)
2005 Excursion (Big Pig)
Old Feb 9, 2005 | 04:47 AM
GB's Avatar
GB
Great Cornholio
It must be the shifter cable because it's black and it seems to be real bouncy as you described. Appreciate the info, is that a pretty simple job, what's involved with it.
SLEEPER
Old Feb 9, 2005 | 07:24 AM
BigDawg's Avatar
Is the car an AOD or T5? If its an AOD, then you will need to drop the H pipe, and crossmember to get to the top of the linkage to replace. Is the speedometer bouncing around, if it is, and it is grey the it is the speedometer cable, other wise, its the shifter cable or clutch cable.
Ryan
Old Feb 9, 2005 | 03:24 PM
GB's Avatar
GB
Great Cornholio
It's a T5 and it is a black cable about the same thickness as a pencil. I looked up under there again today and it had a red fluid drop that was hanging from the cable about to hit the floor. You can also see where the fluid has dripped on the h-pipe, it's not alot but there is fluid. I'm going to have to jack the car up this weekend and see where the cable goes and where it comes from.
SLEEPER
Old Feb 9, 2005 | 03:53 PM
$hawn's Avatar
lives in a glass house
It has to be the speedo as fluid does not travel through the shift cable.
NIGHTRIDER
Apr 16, 2004 07:52 AM
