Another Fox rear disc conversion topic
Old Jan 26, 2005 | 05:02 AM
ODB's Avatar
ODB
S.Y.L.O.
Default Another Fox rear disc conversion topic
I just picked up 2 axels, calipers, discs and brackets from a fellow TR bud. He says they are out of a 93 cobra. They are 4 lug. What else will I need to do to have these work proberly? Do I need to change master cylinder or valve below it? Thanks for the input. I will post pics of the stuff shortly. I am putting tem into a 90 notch with an 8.8 rear.
Old Jan 26, 2005 | 05:09 AM
ODB's Avatar
ODB
S.Y.L.O.
Originally posted by Fordified
Any time you swap the rear to disks you'll need a new master cylinder designed to move more fluid to the rears, and you'll also need to mod the prop valve below it for the same reason.
what do you suggest for master cylinder?? what about mod of prop valve? I heard something of a spring that needs to be removed? help me out.
Old Jan 26, 2005 | 05:43 AM
Strokd85's Avatar
Daddy-O
pick up the aerospace MC, it already has the appropriate valving setup.
I am your penalty.....
Old Jan 26, 2005 | 05:46 AM
ODB's Avatar
ODB
S.Y.L.O.
Here is what I have...I think I got a good deal...sounds like no mods....Oldman said he had a mutha of a time trying to get his right..
Old Jan 26, 2005 | 05:52 AM
ODB's Avatar
ODB
S.Y.L.O.
will my stock brake lines stay and fit in place??
Old Jan 26, 2005 | 07:43 AM
OldMan's Avatar
Donut Killer
Bro,
I did have a mutha, but it was my own doing. I used a Lincoln rear and that was most of it. The axles were too long and I did not like the tire rubbing. I went back to a stock lenght axle and then had to modify the caliper mounting brackets. I used the brake lines from the Lincoln rear and did not change the master cylinder yet. I am going to do that, as the brakes are a little soft.
However, with your setup, I can't see you needing that. The 93 Cobra did not come with a different master cylinder that I am aware of. I doubt the brake lines will be an exact match, but I am sure you can work something out there? I would look at replace those rotors, as they are cheap these days. I picked up new ones for the conversion for $22 each. It also looks like those axles have the anti-lock gear pressed on them? Those might need to come off, but it is all off an 8.8 with the same body width. I would think you are going to be much better off than the path that I took!
Post up on the progress....
SC Motorsports
11801 State Road 52
Hudson, FL 34669-3092
(727) 856-8768
FordSpeed Racing
11733 66th St., Unit 123
Largo, FL 33773
(727) 549-8255
Dynojet Chassis Dyno
Old Jan 26, 2005 | 08:42 AM
ODB's Avatar
ODB
S.Y.L.O.
so the gear portion of that should come off?? And you don't think they are the from a 93 cobra? Thanks..
