Ford 360
Old Jan 10, 2005 | 05:54 PM
Road Rage's Avatar
Shake n' Bake
Default Ford 360
Anyone know if you can fit 390 heads onto a 360?
Old Jan 10, 2005 | 08:47 PM
shinysideup's Avatar
TR Balla Donor Supreme
390/428 is an FE motor, the 360 isnt. sorry way different.
Old Jan 10, 2005 | 10:08 PM
69 Mach 1's Avatar
Fry Rice
Road rage dont put your hopes down so fast, fortunately for you shinysideups statement was incorrect.
Both the 390 and 360 are FE motors, I really am not certain if all FE motor heads are interchangeable but my guess is that they are. Hope that brought your spirits back up after shinysideup smashed them into the ground! im jp. I'll look into it and make sure they are interchangeable for you.
EDIT: Ok yes good news 360/390 heads can be changed! They are the same motor with different strokes 360=3.5... 390=3.78
AIM: AndrewPaulJones
Old Jan 11, 2005 | 11:23 AM
musclemustang83's Avatar
HardCore
yes the 360 is a fe engine they are all manufactured from the factory as 352 blocks and bored from there and stroked with different cranks, any time i have dealed with them they have been the same heads
Old Jan 11, 2005 | 11:53 AM
Road Rage's Avatar
Shake n' Bake
Alright thanks alot..
Old Jan 12, 2005 | 02:07 AM
69Boss521's Avatar
PORK CHOP SAMICHES!!!!!
352, 360, 390, 428.... same motor.... different rotating gear inside. I have a 390 with 352 heads, I have also heard of guys with non cobra 428's running 390 heads. Higher compression....
Old Jan 12, 2005 | 05:18 AM
sorry for the bad info dude
