need help with explorer
Well my very rear door handle broke so now I can't open the rear door or glass. Anyone know how to fix this? Or how to get the door open even? Any help will be appreciated. Thanks.
is there a panel on the interior that you can take off? then if it works like a tailgate on a truck, there will be a bolt with two cables connected to it. turn that bolt and push, and it will release the hinge pins, hopefully letting you open the door.
but see if you can crawl into the back and take things apart and then just work from there
again, its only a thought
