head leaking coolant?
Ive had a coolant leak ever since i put the top half of the motor back together. Ive just thought it was a heater core line or something in that area that was just pissing out whenever the rpms reach above 3k. ne ways i changed the heater core lines today since the coolant trail is going down the bellhousing. i asked a buddy of mine to come over and rev the car up to 4k for me to check out if theres ne more leaks. i saw that the passenger side head cyl #4 right by the last head bolt is PIssing out a good amount of coolant and is steaming from contact with the header. I used teflon when i put the head bolts in. brand new arp bolts. wtf. i guess it didnt seal right or i didnt get enough teflon on that last head bolt? i just dont understand why coolant it all the way on top of the bellhousing from a leak that is happening all the way down by the header. is this an easy fix where i just pull the vavle cover and header and re torque the head bolt? or am i looking at something thats gonna make me angry
feel free to chim in ur ideas.
thanks in advanced
david
thanks in advanced
david
There's a locating dowel right there. Could be you got it in a little crooked and it's not pulling the head down all the way. Been there, done that, bought the T-shirt.
YO! Barry! You LOST!
[QUOTE]Originally posted by DrDirt
[B]There's a locating dowel right there. Could be you got it in a little crooked and it's not pulling the head down all the way. Been there, done that, bought the T-shirt.
Well ive pulled them twice in the last 3 months. i remeber the frist time the dowel came out and i had to add another one to the block to get the head seated right. im almost possitive we did it rite this time too. and yes i used teflon on every head bolt. is this something i should pull the head for? is it serious, can ne damage happen to the head itself from a coolant leak? im gonna try getting to the head bolt and backing it out, reteflon it and torque it back down and see what happends from there. if it still leaks so be it .. im not pulling that bitch again.
Originally posted by Drewpw4ng
i used teflon paste. its a sealant and a water repelant
Those numbers should work. You can try resealing the one bolt. If that doesn't work, I'd peel 'em off again and check 'em out. Don't want to run out of coolant at an inopportune time.
