Nitrous question ...
Old Aug 1, 2004 | 03:11 PM
TheShow50h's Avatar
The little 5.0 that could
Default Nitrous question ...
I believe what I am asking is called a window switch, but I want to be able to hold down a button to turn the spray off while I'm shifting to preserve my t5 the best I can.
I was wondering if it is feasible to wire this "window switch" to a button on a hurst shifter knob so I could just hold it in while I shift and let it go when the clutch engages.
Or maybe I could just set the nitrous up to the button on the shifter rather than having a wot switch?
What do you guys suggest?
-Vince
Old Aug 1, 2004 | 03:20 PM
TheShow50h's Avatar
Originally posted by Mars_302
Well a window swtich is where it will activate something at a certain rpm, then turn it off another another.
Then what I need is a window switch to activate at say 2,500-3,000rpms and shut off at 4500-5000rpms.
-Vince
Old Aug 1, 2004 | 03:29 PM
herrcomestrouble's Avatar
just get a WOT switch.. when u lift to shift.. it doesnt spray.. simple.... But it sounds like you are describing a momentary switch...
Sn95' Tripple Black Cobra
Mods:Heads/Cam/Intake/Exhaust...just your typical stock mustang...
Old Aug 1, 2004 | 03:42 PM
78mphgpr's Avatar
under estimated
You can use a simple relay to cut power to the solinoids when you push the button. I think using a WOT switch would be better for your situation if you are trying to preserve your t-5, because I am sure that you are not going to be powershifting.
Old Aug 1, 2004 | 04:02 PM
HybridSS's Avatar
I have fuzzy eyebrows
yeah...WOT switch in conjunction with a window switch is a good idea.
if it's cheap & reliable, it ain't fast, if it's fast & cheap, it ain't reliable, if it's fast & reliable, it ain't cheap
Old Aug 1, 2004 | 04:05 PM
TheShow50h's Avatar
Yea, I'm just trying to go about things as safe as possible. I'm figuring a 75-125 dry shot will suffice. My a:f was 10.1:1 on an all motor pull, so I'd say I'm safe with no other fuel upgrades.
-Vince
Old Aug 1, 2004 | 04:49 PM
sprayin stang's Avatar
just drive it like you stole it. thats what i do. im surprized my t-5 is still alive. but apparently, these things can take a beatin'.
Old Aug 1, 2004 | 04:50 PM
BlackSunshine's Avatar
I know a guy on here who ran all kinds of quick 11 sec passes with a T-5.
"Gripping the wheel his knuckles went white with desire, the wheels of his mustang exploding on the highway like a slug from a .45. True death. 400 horsepower of maximum performance piercing the night, this is Black Sunshine"
Old Aug 1, 2004 | 06:14 PM
TheShow50h's Avatar
Some hold, some don't. Mine seems to be one of the good ones, but with another 100hp and 150lbs of torque, who knows.
-Vince
