Nitrous question ...
Originally posted by TheShow50h
Yea, I'm just trying to go about things as safe as possible. I'm figuring a 75-125 dry shot will suffice. My a:f was 10.1:1 on an all motor pull, so I'd say I'm safe with no other fuel upgrades.
just go with a WOT switch, you're going to be off of the throttle when you shift (i'm assuming that you're not power shifting) so all the other will be un-neccessary.
I am your penalty.....
-Vince
-Vince
Originally posted by stockstang
Go with a ZEX kit. It is really awesome and it will take care your fuel worries. If your all the way off the gas then then the nitrous should be off. That is if there is no delay. Correct me if I am thinking about this wrong.
The Zex kit also will shut off nitrous flow if the Nitrous Management Unit see a drop in fuel pressure. I don't know if you got a kit or are piecing something together, but I thought I would mention it.
John
1992 Mustang LX 5.0-Powerdyne BD-11A, 3.73's, FRPP clutch, chrome Ponies, Mac headers, Aeromotive regulator, MSD 6A, MSD BTM, FRPP 42# injectors, Pro-Flow Air Optimizer, Trick Flow Track Heat intake, Edelbrock 75MM TB, AFM Power Pipe
John
Originally posted by bottlefedLX
With the Zex kit, it only sprays at WOT, no other throttle postition. It uses TPS voltage wired to a Nitrous Management Unit as the switch, not an actually switch. As I understand it, I have heard it is bad to spray at anything but WOT, probably having to do with fuel pressure and fuel/nitrous mixture.
-Vince
-Vince
Originally posted by HybridSS
yeah...WOT switch in conjunction with a window switch is a good idea.
The WOT switch is so that is engaged only when you are full throttle. The Window Switch is another safe guard, so if you miss that shift and then hit WOT in neutral… well, that's bad... mmmm kay
What ever you do start putting some money away for a tranny.It might hold for a while,but it's not gonna last forever.
Visit my TR Shop Forum
RIP Chester P.Anderson Jr.9/23/05 I love you dad,and miss you very much.
RIP Kevin"Slo SI" 9/13/06,we will miss you homie,time heals wounds but you will never be forgotten
-Vince
-Vince
