Keeping cool...
I use the Griffin in my car.It works awsome.I dont know what your using for a fan,but I use the SN 95 fan.More power =more heat.
It used to be really quick,Now its going to be really FAST!
What ever radiator you get just make sure the tanks are welded on. If you do any custom stuff like me, you cant weld on a radiator with glued tanks. I use a Afco radiator. Works great.
What kind of fan do you have?
Afco... the Iv had 31x19s fit in a fox body... all problems solved... also try and get a sn95 fan.. or 1 off a Lincoln mark VIII.. same thing.. awsome fan. regular black magic and such run about 2,200cfm.. the SN95 fan pulls approx 3,200cfm... :o
Sn95' Tripple Black Cobra
Mods:Heads/Cam/Intake/Exhaust...just your typical stock mustang...
about the same... i believe... The mounts wont work.. you have to cut the corners off and use the lil plugs to mount it to the radiator... its some custom work. But i would rather have that, then havea set of 1200$ heads get trashed...
