Traction problems, new times
Old May 29, 2004 | 11:02 PM
mustangman98's Avatar
Mullet Powered
Default Traction problems, new times
welll after going through a very long and painstaking break in period i finally turned the stang loose tonight. well as i figured i cannot get traction for shit if i try and launch hard. i have a g-tech meter and it has read perfect since ive had it. and here are the results after tonight.
1st run with heavy spinning and a horrible 60' of a 2.789 i ran a 15.1 which sucks.
next run i got a little better traction and pulled a 13.6 but still spinning massive until i hit 3rd.
had a few run after that which were all about the same times between 13.8-13.2, then.................
finally the best run i had all night was a 12.6 with a perfect launch and powershifting, it was a flawless run.
my best hp and torque are 300hp and 342 ft lbs.
only suspension mods i have are kenny brown sub frames, springs, and a set of 50/50 lakewood's. which im searching desperatly for the right set of upper and lower control arms. im hoping for a 12.3 with DR's. and i cant wait to get the 150 shot going so i cant get into the 11's
03 Gt - SOLD!
88 LX Coupe - 308 with a few mods...
Old May 29, 2004 | 11:05 PM
formula69's Avatar
blowed up
and i am proud to say he ran a 12.6 while racing me
Originally Posted by 05general lee
im FAT!!!!
Originally Posted by Little Nicky
Scott is my body guard
T.R. $100,000 kill club member #002
Turtle crew member #2
Old May 29, 2004 | 11:11 PM
Mullet Powered
damn right, i still cant believe i hook'd up that good
03 Gt - SOLD!
Old May 29, 2004 | 11:27 PM
TheShow50h's Avatar
The little 5.0 that could
All motor 2v? Impressive.
-Vince
Old May 30, 2004 | 08:12 AM
TIM TIM TIM's Avatar
could be worse
+1
aim:because tim said
Old May 30, 2004 | 09:57 AM
herrcomestrouble's Avatar
He got those #s using the G-Tech Comp Pro... who knows how close they are?.... but I agree all motor 2v 300wp is Impressive.
Sn95' Tripple Black Cobra
Mods:Heads/Cam/Intake/Exhaust...just your typical stock mustang...
Old May 30, 2004 | 10:25 AM
MustangMosachi's Avatar
Breaking the Broken
congratulations those are some prety impresive numbers!
"Try to make ends meet
You're a slave to money then you die"
Old May 30, 2004 | 02:26 PM
TheShow50h's Avatar
Tell us your mods mustangman, cams? Head work?
-Vince
Old May 30, 2004 | 07:21 PM
Mullet Powered
well my buddy has the g-tech actually. its not mine but after you calibrate it completely it is really close as long as you dont hit a bump or spin sideways or anything, his dyno from secret services said 393 and thats what the dyno said also but i think his Tq was off by like 3 ft lbs.
03 Gt - SOLD!
Old May 30, 2004 | 07:24 PM
Mullet Powered
well, it has all forged internals with a PI head swap and pretty much every possible part that someone could put on it. long tubes, pullies, intake plentum from C&L, mass air meter, TB, aluminum driveshaft, 3:73 gears, king cobra clutch, and all controlled by a custom tuned diablo sport delta chip.
probably more stuff im just forgeting.
03 Gt - SOLD!
