Traction problems, new times
Old May 31, 2004 | 09:27 AM
Domestic Disturbance's Avatar
you done any cams?
R.I.P Bryan Asay
Blonde girl 1: "Whasts a hemi?"
Blonde girl 2:"its a truck for a motor"
4 mechanically inclined guys:"what the fuck did you just say?"
Old May 31, 2004 | 10:27 AM
formula69's Avatar
blowed up
that gtec was very accurate cuz i ran the same one in my car that same nite and pretty much hit my 8th mile ets exactly matching my timeslips.. his 1st gear didnt get traction til higher rpms but once he hooked he pulled hard... i believe every bit of that 12.6 ET
Originally Posted by 05general lee
im FAT!!!!
Originally Posted by Little Nicky
Scott is my body guard
T.R. $100,000 kill club member #002
Turtle crew member #2
Old May 31, 2004 | 10:56 AM
MustangMosachi's Avatar
Breaking the Broken
Originally posted by mustangman98
well, it has all forged internals with a PI head swap and pretty much every possible part that someone could put on it. long tubes, pullies, intake plentum from C&L, mass air meter, TB, aluminum driveshaft, 3:73 gears, king cobra clutch, and all controlled by a custom tuned diablo sport delta chip.
probably more stuff im just forgeting.
is it a 4.6 or do you have a bigger motor in it
"Try to make ends meet
You're a slave to money then you die"
Old May 31, 2004 | 11:01 AM
formula69's Avatar
blowed up
its a 4.6
im FAT!!!!
Old May 31, 2004 | 11:05 AM
Breaking the Broken
Default Re: Traction problems, new times
my best hp and torque are 300hp and 342 ft lbs.
is that wheel or flywheel HP?
Old May 31, 2004 | 11:13 AM
formula69's Avatar
blowed up
i believe the gtec does wheel hp but i could be wrong... it pretty much matched the hp readings from my dyno sheet but my torque was a little off
im FAT!!!!
Old May 31, 2004 | 11:23 AM
  #17 (permalink)
Breaking the Broken
it must be wheel HP and tourque cuz if i dont think he could of ran a 12.6 with 300 flywheel HP unless he has a lot of wight reduction and he is a bad ass drive which he might be. but nice numbers i want to use a g-tech on my car and see what i can do
Old May 31, 2004 | 01:21 PM
  #18 (permalink)
CBRTRX's Avatar
car with tiny wheels
im not doubting your runs at all but i have used the g tech pro in my car and it was crap, way off like it said i had 750 hp and 60 ft times were off too, tried in a friends car after a recalibration for his weight and it was still way off, he only uses it now for a shift light, im sure you can run some good times but i would just take it to the track to know for sure
in memory of Kevin Gonzalez 6/21/86 - 9/13/06
Old May 31, 2004 | 03:49 PM
  #20 (permalink)
formula69's Avatar
blowed up
ive been to sunshine and the gtech matched my timeslips... the same gtech he used too and we barely calibrated it to my car
im FAT!!!!
