So do I put in a automatic ?
Old May 11, 2004 | 08:17 AM
Steve B's Avatar
brings his heater.
im not sure, ive never experienced it.
Old May 11, 2004 | 09:03 AM
Strokd85's Avatar
Daddy-O
Behind cars with power the c-4 tends to flare between the 2nd and 3rd gear shifts. I don't think Mike's has the problem, but he's making around 500rwhp, you're looking at substantially more. I was making that with mine and it flared about 200rpm with my combo. Joe could probably speak more to the issue as well.
I am your penalty.....
Old May 11, 2004 | 09:25 AM
Steve B's Avatar
brings his heater.
man, must be nice to have 900 hp..... , j/k
Old May 11, 2004 | 09:47 AM
Steve B's Avatar
brings his heater.
would a flare be like a slip? like maybe the clutches slipping in the drum from too much power?
Old May 11, 2004 | 12:52 PM
  #17 (permalink)
lt1boyd's Avatar
Their is no dought that with the right converter you will be faster.,i ran around with 456 gears and a 4,500 converter with a auto,for 10years.,in the end i put 373 gears in which helped alot.,. i was not on boost but had a very healthy car.,you will love the track improvement., it will fly.,with boost i do think its a must having a auto.,one thing to add is that a turbo 400 with a converter is a heavy beast, nothing like your stick,you will need to go with a stought rear which im sure you probably allready done,i just think it will become a trailer queen in the end., seems that after all the hp, once you go auto it will be the next step., one thing is for sure and that is you can always switch back!
Old May 11, 2004 | 07:29 PM
  #19 (permalink)
plazma's Avatar
I'd say if you aren't worried about all out speed to stay with a stick. You have to remember the fastest car that is normaly shifted is in the 8's. If they can use a real shift patern and make their tranny survive then I see no reason you can't.
The stick keeps the car more streetable and that can be alot of fun.
Not sure why you can't leave in boost though? Maybe it's a v-8 thing but with a 2 step u should be able to boost in a stick car. Hell we have a 2.3t guy running in the 10's with a t-5 he leaves the line with 10 psi give or take.
https://www.tamparacing.com/forums/signaturepics/sigpic17840_1.gif
My Project
