How much would you pay?
Take into consideration the metal being cleaned off and spot less b4 you gave it to someone
But also if it was painted that the powder coater had to strip it for you
take those into some consideration I would like to hear some in put trying to price some things out
I'd pay for powder. I know of some people who use a toaster oven to do small parts. I'm single, so the oven in the house is fair game.
http://www.harborfreight.com/cpi/cta...emnumber=42802
POWDER COATING SYSTEM
Powder coating is tougher than conventional paint, easy to use and clean up, and covers better. This system provides a minimum 80% transfer efficiency and uses standard powder paints. Includes powder coat system, foot switch, power sourcer, inline filter and two powder cups. 10-15 PSI required input air pressure.
ITEM 42802-4VGA
$79.99
$59.99
ITEM 42802-4VGA
$79.99
$59.99
not sure what others charge, but If I were doing it I'd charge the cost of the powder/materials plus $25 ea. Other parts would be more if more complex. Your time is worth something, that's what others tend to forget...
I am your penalty.....
You may think about investing in a sand or bead blaster. There is no way around you having to do the prep yourself...I wouldn't trust a customer to prep the item correctly.
Sandblasting you say???
http://www.harborfreight.com/cpi/cta...emnumber=54493
PORTABLE ABRASIVE BLASTER
30% More Power than Siphon Units
Slight surface rust forces us to sell this heavy duty unit at super-low prices. Won't affect performance. Portable abrasive blasting power where you needed most.
Handles glass beads, sand, and aluminum oxide
2-1/2 gallon/30 lb. capacity seamless polyethylene hopper
5 foot material hose
Heavy duty blast gun with hardened steel nozzle
Minimum compressor requirement: 2 HP, 3.3 CFM @ 90 PSI ; Shipping weight: 6.2 lbs.
17.99
17.99
I dont pay anything since i do it all myself, but for the sake of posting, here's what i usually get for things:
prices include minor prep work (beadblast, wash). If more is needed then prices should be adjusted accordingly. Prices do not include special effects (flames, etc...). Powders requiring multiple coats (base/clear, base/mid/clear) add $5 per step.
Control arms $50/pr
Air cleaner (carb) $30
Alternator housings $30
Brake drums/calipers $50/pr
Brackets $10-$25
Carbs $75 (much more prep work)
Carb intake $75
Large tunnel ram $100-$150
5.0 upper/lower $100
4.6 2v upper $35
4.6 4v complete $150-$175
Oil pan $40-$50
Pulleys $40 for a set
Spindles %50
t-stat housing $20
5.0 Timing cover $40
Trans pan $25
valve covers $50/pr (4cyl $30)
water pump $40
This is a short list, and is definitely not set in stone. There is definitely a "friend" discount, etc...
edit: ricers are charged double as the powdercoat will actually add up to 20 rwhp. outrageous colors such as kawasaki green and bright orange are charged to ricers at triple due to the massive amount of rwhp those colors give.
Control arms $50/pr
Brackets $10-$25
Carb intake $75
4.6 2v upper $35
Oil pan $40-$50
Spindles %50
t-stat housing $20
Trans pan $25
water pump $40
Dave
1998 GT cp (totalled, compliments of a dump truck)
1996 pony (awaiting transplant)
Dave
Dave
Dave
