Brake Master Cylinder
I'm upgrading to larger Baer/Cobra brakes, so I'm thinking it would be wise to go with a Cobra master cylinder in place of my SVO unit. My questions:
Will the hard lines bolt up to the new unit, or will I have to bend new ones?
Will a newer Cobra master cylinder bolt in with no problems? The SVO master cylinder is a popular upgrade for those fox body owners upgrading to the Lincoln Mark VII brakes. Plus the newer style master cylinder bolts into a fox body with no issues...so I'm thinking I won't have a problem going with a newer Cobra master cylinder.
Last question...is this upgrade/swap absolutely necessary? The SVO master cylinder is pretty decent as is for the upgraded factory brakes.
Guest
Posts: n/a
Try it without first and see how it goes. If anything they will be a little soft. I know on my car any upgrade to a sn95 master requires a 3-2 port conversion.
Find Matt90gt on the corral and goto his webpage. It will have like all the specs and everything you will need to know.
