Swaping EFI 5.0 to carb
Old Mar 24, 2004 | 02:49 AM
TampaMCS's Avatar
TR Balla Donor Supreme
Default Swaping EFI 5.0 to carb
Before anyone has a heart attack, this is going in a 68 Mustang w/AOD swap.
I have a 92 Tbird 5.0 that I am going to be removing the EFI from, and hopefully swapping to an Edelbrock Performer RPM Air Gap, but I have heard that the water passages were different on the late model blocks.
Has anyone here ever swapped the efi off a late model and ran an aftermarket carb intake? Did you have to change anything?
2008 Audi A3 2.0T battle wagon
Old Mar 24, 2004 | 06:19 AM
TampaMCS's Avatar
Scott,
Thanks for the 411, I knew I would need the Distributor, I have a mallory unilite out of my 289 (but need the steel gear), the linakge I will pull off the 289.
I am looking to do the edelbrock 5.0 heads/roller rockers a B303 and a holley 670 Street Avenger... You think that would play well with an AOD and a 4.11 rear? I am wondering if I need to swap the T/C out for a higher stall limit...
Since it has no provisions for fuel pumps I assume I could use a holley blue or something along those lines?
Old Mar 24, 2004 | 06:44 AM
Leonard's Avatar
OUCH!!!
I'll take your EFI stuff.
Old Mar 24, 2004 | 06:04 PM
TampaMCS's Avatar
How much $$ I am dumping all the efi stuff I have, lower,upper fuel rail wiring, MAF and distributor. Its all off of a 92 Tbird, and has the intake that looks like the 94-95 5.0 Mustang...
I am looking for $200 for all of it....but everything is negotiable.
Old Mar 24, 2004 | 06:19 PM
bholmes's Avatar
Quimsickle
Dude I just did that swap, it was really no trouble at all except the distributor. I put a msd vaccum advance dist. on and had a lot of trouble with timing and alignment
