tranny questions
Old Mar 22, 2004 | 10:08 AM
Lumberjack's Avatar
is made outa laffy taffy
Default tranny questions
this weekend i am goin to pick up a t-5 to put in my 89 LX 5.0 , i was just wondering if i had to do anything to the computer for the swap. there is an AODE in it now. thanx. i was also wondering if the drive shaft length and tranny mounts were the same?
All-American Street Car Performance
6187 126th ave north
Largo Fl 33773
727-667-9346
www.aastreetcars.com
Old Mar 22, 2004 | 10:18 AM
Alan's Avatar
drives euro trash
You have an AODE in a fox?
You'll need the obvious things like bellhousing, clutch, flywheel, quadrant, brake/clutch pedal set, etc. Pretty sure driveshaft is the same.
My brother ran the same PCM in his 89 GT when he went to a manual transmission. Most people seem to prefer the automatic PCM since it won't pull timing between shifts (or so I hear).
Old Mar 23, 2004 | 03:39 PM
T/S #25's Avatar
Need To Get Quicker
Your AOD driveshaft and tranny mount will work fine, however, you are most likely going to have to cut the welds on the transmission crossmember so you can slide it forward to get it to line up correctly with the T-5.
Joe
FordSpeed Racing
9.78 @ 136.05
www.fordspeedracing.com
Old Mar 25, 2004 | 06:28 AM
Lumberjack's Avatar
thanx for the input guys
Largo Fl 33773
727-667-9346
