Tranny Mount
I called Ford and they dont even make the part/brackets anymore.
I dont want to chisle them off because the brackets and/or the body might get bent to hell.
-Ryan-
-Ryan-
did ya read my post by chance?????
i'm not pullin' that out of my ass............ buy the GT tailhousing from a junkyard or somewhere............ bolt it up and go on with life..........
200 points away from a 300
Originally posted by Mars_302
so I take that cobra tranny I sold you worked ?
it is a lil shaky in 3rd and makes a lil noise........ but its holding up strong...........
the automatic tranny crossmember bolts in so you dont need to do any welding or bs like that. If you cut the manual tranny crossmember brackets off your body, Ford does not sell a replacement nor can you simply "take it off" another car. Try the automatic tranny crossmember, it will simply bolt into your existing holes in the frame and it sits several inches farther back than the manual crossmember.
1986
Originally posted by CarbedNotch92
You're wrong.
You're wrong.
I just know the new tranny is longer then the one I took out.
-Ryan-
-Ryan-
