Suspension Suggestions....
Originally posted by NitroGlycerin
If you want to keep your ride height and hook better, check out the fox spring setup- usually 4-cyl springs up front and v8 springs in the rear (cut to your liking). Def. some 90/10s also... I wouldn't expect much from aftermarket shocks, as the stock shocks are basically 50/50s, on '99-up cars anyway.
-Mike
-Mike
If you want 1.6s or lower this is the way to go.
Foxbody springs/v8 rears.
70/30s are good enough you still drive it on the street..
Leave rear shocks alone.
Take swaybar off.
Or you go your route and Ill do this to mine and well see who will cut better 60's your money!!!
Originally posted by phatstang1
Why is everyone so shy with running the 90/10's on the street? I ran them with no sway bar and the car felt great. No cornering problems, braking problems, etc.
-Jomar-
-Jomar-
hehe, all i have installed as of right now is a set of lowering springs with some worn out ass stock shocks on the back and people are surprised how good it hooks.
and i've never heard of taking off the sway bar???? i think mine is still on. hehehehe??????
03 Gt - SOLD!
88 LX Coupe - 308 with a few mods...
03 Gt - SOLD!
your hooks becuase you only put down 211rwhp
jfwy man.
Well i had some spare time today so i snatched the sway bar off.. and looks like the the lowering springs have some kind of rubber spacer in the fronts to keep them higher than they are supposed to ride. any1 know what those are? I state again.. i no ZERO about how drag suspension works.
jfwy man. Well i had some spare time today so i snatched the sway bar off.. and looks like the the lowering springs have some kind of rubber spacer in the fronts to keep them higher than they are supposed to ride. any1 know what those are? I state again.. i no ZERO about how drag suspension works.
Sn95' Tripple Black Cobra
Mods:Heads/Cam/Intake/Exhaust...just your typical stock mustang...
Guest
Posts: n/a
On one of our customers cars we had. We did tokico 5 way drags shocks all around, moroso trick springs up front and I believe it was 4 banger fox body rear springs, and also SSM rear control arms, both upper and lower. I know he was cutting some pretty good 60 foots on nitto drs and 4.11 gears..
