car hesitating 1900-2800rpm..help!
Old Nov 4, 2003 | 01:59 PM
superdave's Avatar
Unhappy car hesitating 1900-2800rpm..help!
I'm having a problem, and i've run out of ideas for what it could be. Everytime I hit around 1900rpm the car hesitates, almost like a slight miss, and it continues to about 2800rpm. After 3000rpm no problems at all. It happens in every gear, if I throttle it slowly or quickly. The exhaust also has a weird higher pitched tone (even at idle). It's a 98 with a 99 motor, 98 DIS and fuel system. It's run fine for over a year with this setup.
Here's what i've checked:
Ignition working at all rpm (spark)
Injectors are clean/working
all vacuum lines connected/no leaks
all sensors/electrical connected
NO CHECK ENGINE LIGHT
I dont know what else to check. I've thought about the cats...maybe one is clogged. Would that cause a problem at these specific rpms? I havent checked compression yet, mainly because im afraid to.
Any ideas??????
Dave
1998 GT cp (totalled, compliments of a dump truck)
1996 pony (awaiting transplant)
Old Nov 4, 2003 | 07:05 PM
the anti-rice's Avatar
finally painted the car!
Take the exhaust off and check it out. Do you still have the stock one? If so, put that one on and see if that helps. Between 1900-2800 does the exhaust sound different (abnormal)?
-Ryan-
Old Nov 4, 2003 | 07:13 PM
EsCoRtLvR's Avatar
Escort Connoisseur
Could very well be a cat, any weird smells coming from the exhaust or normal? New rattles?
"Genuine" ASE certified Mazda, Hyundai, Isuzu Technician
Escort Enthusiast Site
Automotive Electrical Specialist, Tuning Specialist
Old Nov 4, 2003 | 07:40 PM
Road Rage's Avatar
Shake n' Bake
Time for an off road x-pipe.
Old Nov 4, 2003 | 08:07 PM
EsCoRtLvR's Avatar
Escort Connoisseur
If there were a dead spot in the cam/crank sensor it would happen throughout the RPM range.
Old Nov 4, 2003 | 08:11 PM
351coupe's Avatar
refinish artist
If it was a clogged cat would'nt do it at all RPM's?If you checked everything else,do a compression test.
Visit my TR Shop Forum
RIP Chester P.Anderson Jr.9/23/05 I love you dad,and miss you very much.
RIP Kevin"Slo SI" 9/13/06,we will miss you homie,time heals wounds but you will never be forgotten
Old Nov 4, 2003 | 08:15 PM
EsCoRtLvR's Avatar
Escort Connoisseur
If it were a clogged up cat you may not notice it at lower RPMS because it doesn't need as much flow to idle. At higher RPMS the air could be forcing it's way through there enough to not notice the rough idle as well. When you let off the gas does it make a weird noise?
Old Nov 4, 2003 | 08:26 PM
Road Rage's Avatar
Shake n' Bake
Originally posted by Mars_302
id like to say a dead spot in some crank or cam sensor?
I think if it was something like that it would have thrown a code.
