Fix Matts EFI problem game.
Old Oct 27, 2003 | 09:26 AM
m0nk3y's Avatar
pwns.
solution one: sell for a modular stang
Originally Posted by Lil Ze
Florida is the new Miami through and through.
Old Oct 27, 2003 | 10:43 AM
Bald Guy's Avatar
I like beer.
Put a carb on it.
-Jomar-
Old Oct 27, 2003 | 11:44 AM
T/S #25's Avatar
Need To Get Quicker
We had the same problem on a car a few weeks ago. Not saying that it will 100% fix his car, but we changed the computer on that one and it straightened everything out. TPS voltage went from 5 volts back down to normal.
Joe
FordSpeed Racing
9.78 @ 136.05
www.fordspeedracing.com
Old Oct 27, 2003 | 12:45 PM
EsCoRtLvR's Avatar
Escort Connoisseur
I love how people just change the computer when they can't figure things out First off only the center wire should have a 5v reference on the TPS. It shouldn't even be 5 volts it should be about 4.6 at WOT, at idle around .65-1.25 volts. One of the other two wires should have a straight power and the third should be a ground, I believe. Best bet would be to get a wiring diagram of the computer find which one is supposed to be the 5v reference/memory and which one is supposed to be the straight hot lead for the computer first to make sure that isn't crossed. I can't remember the wiring off-hand though Another thing to note, computers usually only run the grounds in cars as a standard. If you have a hot wire going to a ground, going to the computer, you could definately cause some beautiful things. As far as the bad gas mileage, the car is probably in "limp home" mode meaning it's running full rich because it can't see what the throttle position is at. If you need to I can print out a computer wiring diagram from ALLMOST Data (hehe) and scan it, then send it to you. Just give me the Exact year model etc. Or what year/model the engine is, if it came from another car.
Another note, did you guys check out all the fuses before hardwiring in the computer wire? I know it sounds stupid but you'd be surprised how many of the guys in my school over look that and look into it being something bigger, then they can't figure it out. Come to me whining because I'm the electrical guy, I go over replace the ECU fuse and get back to what I was doing
"Genuine" ASE certified Mazda, Hyundai, Isuzu Technician
Escort Enthusiast Site
Automotive Electrical Specialist, Tuning Specialist
Old Oct 27, 2003 | 01:42 PM
T/S #25's Avatar
Need To Get Quicker
EsCoRtLvR, who says we changed the computer because we couldn't figure the problem out. Maybe after checking the wiring, the problem was diagnosed as the computer being bad after all. All I know is after everything was checked and the new computer was put in, the voltage was back down where it belongs at idle and a sweep of the TPS showed the voltage working correctly.
This wasn't our first picnic by any means.
Joe
FordSpeed Racing
9.78 @ 136.05
Old Oct 27, 2003 | 02:05 PM
EsCoRtLvR's Avatar
Escort Connoisseur
I wasn't directing that towards you T/S...touchy touchy It's just a common thing. Even my teachers are like "ECU is bad replace it" then I go over and look at the wiring find the crossed wire and start up the car.
Old Oct 27, 2003 | 02:28 PM
herrcomestrouble's Avatar
yes all the fuses were checked.. before hard wiring the computer. There was a dead wire found going from the ignition cylinder... to the computer. Matt i'l talk to my brother... he'l come make it right. shit if you want you can use the computer off my old car.... let me know somthin BROTHER!!!
Sn95' Tripple Black Cobra
Mods:Heads/Cam/Intake/Exhaust...just your typical stock mustang...
