ignition problem
Old Oct 2, 2003 | 06:06 PM
stangerang's Avatar
whoopdy fucking do!
Default ignition problem
my car has had an ignition problem for a little while now.......
it started dropping a cylinder at idle, so i changed the plugs and plug wires, and i have fairly new coils on it (97 4.6 2 valve)
so i changed all that and i still have the problem, it throws a check engine light so i pull the codes.....
it says it it detecting a miss in cylinder # 2 ... so i look it all over and everything seems fine.... plug is burning clean and all........
now, it only does this at idle........ so i am trying to figure it out......
i thought it could be something mechanical (leaking/cracked valve) at first but the computer is detecting it, so that means it is not mechanical........
anyone have a clue what it might be?????
the computer also threw some weird emmisions code, that the guy didnt know (autozone though) but i think the emmisoins code is from the rich condition of the cylinder not firing at idle..........
anyone here good with ignition and or OBDII computers......
i would really like to figure it out without spending 100 bux to put it on the ford diagnostic machine..............
any help is appreciated !
200 points away from a 300
Old Oct 2, 2003 | 06:09 PM
Strokd85's Avatar
Daddy-O
can you swap the coils around and see if the problem follows the coil? (don't know much about mod motor ignition, but would be an easy way to isolate the problem).
I am your penalty.....
Old Oct 2, 2003 | 06:16 PM
stangerang's Avatar
whoopdy fucking do!
thought about trying that ,
i'm almost certain that if the coil was bad it would drop all 4 cylinders, not just the 1 .........
and as i said, it only does it at idle............ once you give it some gas it is fine.............. so????????
Old Oct 2, 2003 | 06:26 PM
Strokd85's Avatar
Daddy-O
possible arcing off of a plug wire?
other than that possibly an issue with the injector or how the computer is seeing the injector? pulse width screwing up?
Throwing stuff against the wall, seeing what sticks..
Old Oct 2, 2003 | 06:31 PM
stangerang's Avatar
whoopdy fucking do!
plug wires are brand new motorsport wires......... with no signs of breakage........
and as far as the injector, i thought of that....... but how should i test them???? i know there is a way to do it by checking the ohms, but what should i look for? the electrical or mechanical side of the injectors???
Old Oct 2, 2003 | 06:32 PM
stangerang's Avatar
whoopdy fucking do!
ps, wouldnt the computer just say the injector has gone bad as well??????
Old Oct 2, 2003 | 06:41 PM
Strokd85's Avatar
Daddy-O
honestly don't know man.. you would think, but maybe since it's intermittent it won't just say "hey #2 injector is bad".
I'd lean towards electrical, but check both if possible. as to how, well that's over my head (Sorry)..
Old Oct 3, 2003 | 03:38 AM
catfish's Avatar
No Mam
Disclaimer - I don't know crap about mod motors. That said...
Are the wires exchangeable side to side? Start swapping one component at a time. Wire, then plug, then coil, then injector.
If a plug on the injector was somehow cracked, could it short out. Not sure why it would do it at idle only, but you never know.
What about a vacuum leak causing a miss?
Beer. Now there's a temporary solution. --Homer Simpson
Old Oct 3, 2003 | 08:07 AM
Toma's Avatar
Ricer In Training
Considering the you just changed the plugs and wires I'd swap an injector and run it on the computer again. Last resort swap the coils, see if the Cylinder # is the same.
...or you could drop a B16 in, and never have any problems
"There's more flawless engineering in a Camry than all the berlinettas Enzo ever conjured while lying next to mistresses." - John Phillips/Car and Driver
The swapped hatch hotness
Slow Five-Oh Rustang
