Mustang to Ty-Stang ??
Old Sep 10, 2003 | 11:33 AM
CBRF3er's Avatar
Forget the Typhoon, that is a waste of a good coupe
Old Sep 10, 2003 | 03:11 PM
Charles's Avatar
Senior Member
Yeah 89 Stangs are rare and are really worth a ton of $ these days
92' Nissan 240sx
02' Honda VFR Interceptor
08' Tundra
Old Sep 10, 2003 | 03:19 PM
craig_302's Avatar
boostmonkey
They are even bettar than 4 door Integras, I bet. Those are the most bestest cars evar!
Old Sep 10, 2003 | 05:43 PM
Road Rage's Avatar
Shake n' Bake
Old Sep 10, 2003 | 06:09 PM
StuntMan's Avatar
Driver
Am I the only one who thinks that is a waste of both the engine and car? First of all a 5.0 would not be hard to find, much easier to install in the fox body and most likely be much cheap. Second I thought the Syclones and Typhoons where allwheel drive but the Mustang appears to be only rear wheel drive? You can find S-10s for dirt cheap why not just throw the motor in a S-10 I dont think the Mustang would be lighter than a S-10? but I guess if I had that motor and that car(w/o a motor) I would try to make them work together to.
If speed kills then I'm suicidal
Old Sep 11, 2003 | 08:37 AM
Charles's Avatar
Senior Member
That stang is a lot lighter than a S-10 and I think it's mainly just because he felt like it and to cause a stir
92' Nissan 240sx
08' Tundra
Old Jan 12, 2005 | 11:13 PM
  #17 (permalink)
Charles's Avatar
Senior Member
Update....
Quote from thread below....
"The tystang ran a best of 7.61 @ 98mph tonight with a shitty 1.899 60'. I left off idle off the line and had to peddle most of the way down the 1/8th b/c of was spinning the mcreary's hard enough to where it would over-rev and backfire. So most of the 1/8 was 1/2 to 3/4 throttle at around 3500-5000 rpms. After letting out at the 1/8 it would coast to a 12.6 @ 82mph. I know there's a ton left in her. This was at 19psi pump gas and 2560lbs without me in it. And I still have alot of weight to remove. I figured with this 60' in the quarter it would go 11.80's at 124mph. Still peddling and not wot. Man if i can just bury the throttle or even get a couple psi off the line it would rip. Most of the time i'm just waiting for it to spool up through the first 60'"
http://www.syty.net/phpBB2/viewtopic...28880&start=60
92' Nissan 240sx
08' Tundra
Old Jan 13, 2005 | 07:57 AM
  #18 (permalink)
Stangonline's Avatar
Great... take the most interesting thing about a sy-ty (AWD) and throw it out the window....morons....
Now, make an AWD stang that doesnt weigh 3800-4000lbs and I would be interested.
Jeff
93 Coupe - check out my blog - http://www.93coupe.com
01 Cobra - Stockified - Wife Owned and operated
68 Coupe PROJECT <- Been in the family for 25 years!
Old Jan 13, 2005 | 07:00 PM
  #19 (permalink)
Charles's Avatar
Senior Member
I think the whole point was power:weight ratio for a drag setup with the 4.3. If he wanted something 4k lbs instead of 2,500 he would have just left it in a truck
92' Nissan 240sx
08' Tundra
Old Jan 13, 2005 | 10:17 PM
  #20 (permalink)
SpyVO's Avatar
I think you missed a 'doesn't' in there...
Either way, Mustangs are pretty much throwaways, and I'll bet anyone that they will be restamped someday, just like '69 Camaros are.
As for the SyTy parts, not all are specific to the vehicle. If you were inclined to build a clone, you could do most of it by using parts sourced from non-SyTys, I think. Just like a Mustang SVO, or a Cobra.
'93 Coupe
"Notches kick ass!"
