Track Event Protocal / General Rules
Old Aug 14, 2003 | 07:15 PM
  #21 (permalink)
Fast240Z's Avatar
The King
Default Race fuel?
Originally posted by Sneakin Deacon
what do they normally charge a gallon? only reason id use it is if im right on the verge of 13's i usually see about 1 tenth and 2-3mph from it.
My 2 cents,
I am no expert but you should be careful running race fuel in your car. Basicly the higher the octane of the fuel the slower it burns. That is why you need it in higher compression engines to prevent pre-ignition. All gasolines, race or otherwise, are fundimentally the same hydrocarbon chain and work the same. Race fuels do not contain some mystery additives which make a bigger bang(more power). They just are the nessecery evil when you have high compression or high boost/NOS with high compression. There are fuels other then alky and nitro which have higher oxygen properties allowing them to burn hotter(bigger bang=more power) but they are very expensive $50 gallon.
I just hate to see people waste money if they don't have to. I would rather see you put pump gas in your car and buy all your friends sodas with the extra money.
I personally run 93 octane pump gas in my car and have had no change with race fuel. If you like the way it smells then go for it, but I would save my money.
STS Power Dealer
www.pcstreetcars.com
Old Aug 14, 2003 | 08:03 PM
  #22 (permalink)
Jordan Y.'s Avatar
15 seconds EXHILARATION
He may be talking about his experience with his last car, a plymouth laser awd. I believe you were running 17 psi, stock fuel system, right kenny? At that point it was probably the reduction in knock and increase in timing advance that would make that difference, right?
But there should be no need for it with his new naturally aspirated car... but he must have his reasons, I suppose.
Old Aug 14, 2003 | 08:29 PM
  #23 (permalink)
HybridSS's Avatar
I have fuzzy eyebrows
I agree with the above two posts...if your not having any detonation issues...use the 93. I lose hp when going from 93 to 100 octane on motor unless I give it a little more timing...but then it usually only brings me back to were I was with the 93 and less timing.
if it's cheap & reliable, it ain't fast, if it's fast & cheap, it ain't reliable, if it's fast & reliable, it ain't cheap
Old Aug 15, 2003 | 08:35 AM
  #24 (permalink)
Sneakin Deacon's Avatar
PSSHHH x2
okay, thanks for clearing up my misconceptions. in the laser i was getting about 5-9 knock counts thats why i went to to race gas and i picked up about .15 and 3mph..well atleast ill be saving a lil bit of money
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
Old Aug 15, 2003 | 09:40 AM
  #25 (permalink)
954RR's Avatar
Anybody bringing Nutec or Ultimate-4 that I could buy a gallon or 2 from?
Still hoping the weather holds.(fingers crossed)
2002 954RR
-135rwhp
0-110mph in 6.7 seconds
Old Aug 15, 2003 | 01:46 PM
  #26 (permalink)
T/S #25's Avatar
Need To Get Quicker
Don't know about the Nutec or Ultimate-4, but I can bring some VP 110 if you need.
Joe
FordSpeed Racing
9.78 @ 136.05
www.fordspeedracing.com
Old Aug 15, 2003 | 08:23 PM
  #28 (permalink)
TheShow50h's Avatar
The little 5.0 that could
Ya, it isn't projected to be as grim as i had first suspected from all this rain, we should be good to go.
-Vince
Old Aug 15, 2003 | 10:06 PM
  #29 (permalink)
351coupe's Avatar
refinish artist
Agreed with Fast240,when I put a mix of 93/110 in my stock GT,I dropped two tenths in the 1/8th.It sucked because I had to keep running shittier times than I was used to.
Visit my TR Shop Forum
RIP Chester P.Anderson Jr.9/23/05 I love you dad,and miss you very much.
RIP Kevin"Slo SI" 9/13/06,we will miss you homie,time heals wounds but you will never be forgotten
Old Aug 16, 2003 | 10:10 AM
  #30 (permalink)
Boostin97SE-R's Avatar
Resident Asshole
I guess i am just gonna have to run through the box with all four tires. I need to wet them a little to clean them off. Trying to spend them dry will result in bad wheel hop which is murder to weak nissan trannies. Does anyone have a definate answer or what?
R.I.P Dad.
The greatest man I've ever known.
6/14/43 - 7/11/06 2:24am
