Zex Kit ?? Wet or Dry ??
Old Jul 28, 2003 | 12:28 PM
02SilverStanger's Avatar
Originally posted by black91gt5.0
so how about the nitrous kit 02silverstanger?
Thanks for the offer, however I am still not to comfortable with using nitrous, I had heard that the Zex kits were the safest, but have now read a few horror stories with Zex kits to. So I am going to hold off for now.
Rob
02 Saleen S281SC Vert
04 CBR600RR
Old Jul 31, 2003 | 09:38 AM
BLUE2KSS's Avatar
Mechanical Engineer
you will hear horror stories of all kits. just dont be stupid and you are fine.
Old Jul 31, 2003 | 10:04 AM
Fatback302's Avatar
EYES LIKE A BAT
just us it mustangs love zex
Slappin down cobras since 2004...
Old Jul 31, 2003 | 10:27 AM
thats just it...I do not know how to use Nitrous, so its not that I would puposely be stupid...I just wouldn't know any better until it was too late...Thats why I was looking for the safest kit for my car....and not just the basic kit...
Rob
04 CBR600RR
Old Jul 31, 2003 | 12:48 PM
NitroGlycerin's Avatar
World Skee-Ball Champion
You should be ok with a 100 shot wet, with RPM window switch set for 3k-6k RPM operation, electronic wide open throttle switch, and fuel pressure safety switch. With dyno tuning and a custom chip, it's quite safe.
'99 GT 35th Anniv - 13.01 @ 107.4 w/ cams & bolt-ons - Sold
'03 Audi A4 1.8TQ - :gordy:
► Home Buying & Selling Finance Tips ◄
[/b]
Old Jul 31, 2003 | 12:55 PM
stangerang's Avatar
whoopdy fucking do!
nirous is very safe if you just get a wideband done and make sure it is a safe AF ratio
and a wet kit or dry kit can be tune by switching the jets, so actually you really do not have to tune the computer (it is better to do so) but you dont have to..........
if i were you i would get a computer chip........ so you can change the AF/ timing .........
a timing adjuster is like $175 so it is cheaper in the long run to just get a chip and do the timing that way...........
jms or a flip chip is good to have so you can run an all motor setting and a nitrous setting, one with timing advanced, and a leaner AF and one with timing retard and a richer AF
200 points away from a 300
Old Aug 1, 2003 | 01:35 PM
  #17 (permalink)
I already have a chip, with what the mods I have done would I need to get a retune? My A/F ratio 11.7
Mods:
Suspension: Steeda Springs, Steeda Caster/Camber plates, Steeda Strut Tower Brace
Drive Train: 3.73 Pro 5.0 Gear, FR Aluminum Drive Shaft
Induction:K&N Filter,UPR Aluminum CAI, FR 70mm Throttle Body
Exhaust: Magna Flow X pipe w/ cats, Magnaflow Cat Back
Other Mods: Diablo Sport Chip(Tune by Ford CHips), Steeda Tri-ax Shifter, Speed Cal
Rob
04 CBR600RR
Old Aug 1, 2003 | 02:07 PM
  #18 (permalink)
stangerang's Avatar
whoopdy fucking do!
with that tune the timing is prolly advanced......... so id have it set back to stock and or retarded a few degrees from stock.....
everything looks good if you get the timing in order...........
Old Aug 1, 2003 | 02:17 PM
  #19 (permalink)
01silverls's Avatar
bullshitter #1
I don t know that much about wet or dry systems , stangs sorry wish I could be more heip
Old Aug 2, 2003 | 09:49 AM
  #20 (permalink)
BLUE2KSS's Avatar
Mechanical Engineer
all the kits come with directions. and they are very simple to follow. if you buy my zex kit it comes with all the directions for it. you set it up so you only actually spray at wide open throttle. it is very simple and self explanatory once you see everything. not to hard. i didnt know that much until i read the directions either.
