The Ford Forum Lounge Off Topic Group for Ford Forum Members or other regulars. Keep it work safe please. No tech posts.
Question about O ringed heads
Old Feb 18, 2009 | 04:07 PM
fuelie327's Avatar
Default Question about O ringed heads
I recently tore down a motor with O ringed heads , but it did not have O ringed head gaskets.It had standard head gaskets.I saw this motor run in a car about 14 or 15 passes at the track and it ran real good.If the gaskets don't matter why would these heads be O ringed? Any info would be appreciated.
Old Feb 18, 2009 | 04:12 PM
Zman's Avatar
I gota Cheby
The metal ring is not in the gasket but actually its in the heads. double check the heads to make sure its not there. And if its not thats ok will not hurt anything. I assume as in your title fuelie327 your a chevy guy? Fords have a weak point on cylinder head sealing. Only 4 bolts around the cylinder as chevy has 5. Luckly for Ford, head gasket design has improved a lot.
Only 1/4 mile track I know is Gandy Bridge
Old Feb 18, 2009 | 04:15 PM
red vert's Avatar
welcome to Tampa Ricing
The new Fel Pro gasket has the o-ring in the fire ring, very hard to tell. If it is from a small ford 9001 will be stamped in the gasket.
Old Feb 18, 2009 | 04:49 PM
fuelie327's Avatar
Yeah, I still am Chevy at heart,but have recently converted to Ford.Got a pretty decent fox body recently and I'm putting these heads back on the motor they came off of.There are no rings in the grooves on either head.But thanx for the info.
Old Feb 18, 2009 | 06:09 PM
shinysideup's Avatar
TR Balla Donor Supreme
You can put the copper wire in the grooves. I o-ring the block with an Isky tool.
Old Feb 19, 2009 | 02:39 AM
fuelie327's Avatar
well,your a perv cause my sister is 10 years old
Old Feb 19, 2009 | 02:46 AM
864I'DCaprI's Avatar
doowutchyalike
After \/
______________________________
Is his sig!!!!!!!!!!
He wasent saying that to you............random much!!!!!!! Wheres the pedobear!!!!!!!!
Hes not this!!!
(C)lassic (A)merican (P)erformance (R)acing (I)nspired
Old Feb 19, 2009 | 04:47 AM
Zman's Avatar
I gota Cheby
I must have missed something?
Old Feb 19, 2009 | 04:53 AM
doowutchyalike
LOL, Andel, in Joe's sig it says "I May Not Go Down In History, But I'll Go Down On your Sister. " and fuelie must have taking that (not knowing its just a sig saying) as Joe talking to him about his sis....than I just added what I did, I was half asleep!!
Old Feb 19, 2009 | 05:56 AM
Zman's Avatar
I gota Cheby
thanks for the clarification
