The Ford Forum Lounge Off Topic Group for Ford Forum Members or other regulars. Keep it work safe please. No tech posts.
head questions...
Old Nov 15, 2008 | 07:36 PM
Stealth Mode's Avatar
Still CREEPIN
Default head questions...
1. from wat i understand the 351W's intake is 2" wider than the 302 intake, correct or no?
2.will 302 heads work on a 351W, and will they raise the compression of the engine, and can i gain any type of hp/tq, on the bottom, mid and high end's?
ive heard alot of ppl say that u can pull hp/tq from 351 heads on a 302, is it the other way around too?
TurboRAM Member #5
24psi & Stable
GET SOME
Old Nov 15, 2008 | 08:54 PM
95coBraSVT's Avatar
banana republic
1) The extra intake width is from the deck height being higher, nothing else.
2) The 302 heads WILL work on a 351W, but you will need to drill out the bolt holes. How do I know this? Because I have 302 heads which I used on a 351w for some time.
3) Do they raise compression? Well, not really unless you have them decked.
4) You can only gain hp and tq numbers from interchanging the 302/351w heads if you use OLD 351w heads (1970 I think) or the old 260 heads which had the smaller combustion chambers.
Originally Posted by rotarykidd
maybe i just like rainbows and puke, who says it has to be a gay thing?
Old Nov 16, 2008 | 12:39 AM
Still CREEPIN
ok so next question, would it be better, to just buy a set of frpp and send em to fox lake for the work over?
TurboRAM Member #5
24psi & Stable
GET SOME
Old Nov 16, 2008 | 06:27 AM
95coBraSVT's Avatar
banana republic
Yes
Old Nov 16, 2008 | 07:49 AM
$hawn's Avatar
lives in a glass house
actually, buy almost anything BUT a FRPP head. most any other mfg. of will make more power.
Old Nov 16, 2008 | 03:10 PM
95coBraSVT's Avatar
banana republic
This is also true $hawn. However, he asked a fairly simple and specific question. I answered as simplisticly as I could. He WOULD definatly be better off with the FRPP heads worked over than a set of stock 302 or 351w heads worked over. Of course, he would be even better off with a set of World Products or something similar worked over.
Old Nov 16, 2008 | 04:22 PM
$hawn's Avatar
nothing was directed at you?
Old Nov 16, 2008 | 07:26 PM
Still CREEPIN
naaa, a couple buddies of mine run world products and say their shitty, personally i like brodix heads, but the price tag on them r about as much as AFR, pretty much FRPP is a good buy considering the price and hp/tq u get out of em.i dont mind paying 1200 for a set of FRPP's, but wen the next head is 18-1900 bux and only makes 10hp/tq more, its not really worth it.
TurboRAM Member #5
24psi & Stable
GET SOME
Old Nov 17, 2008 | 03:45 AM
GNs-r-slow's Avatar
Bondsman
I'd spend money on the WP heads before the FRPP's. Really only difference between WP's and some good aluminums is the weight difference.
Old Nov 17, 2008 | 04:49 AM
95coBraSVT's Avatar
banana republic
I know. I was just explaining my answer a bit more.
