The Ford Forum Lounge Off Topic Group for Ford Forum Members or other regulars. Keep it work safe please. No tech posts.
head questions...
Old Nov 17, 2008 | 05:17 AM
Tiffiny's Avatar
I can fix your bullshit
there is more than a couple hp difference with aftermarket heads
Old Nov 17, 2008 | 09:40 AM
95coBraSVT's Avatar
banana republic
best Performance for the money - AFR
Many are less expensive, but few produce the same results IMO. Plus, the AFR heads perform out of the box whereas other heads need to be "worked" or ported with a "stage 1" or higher to produce the same numbers. If you have the $$$ for the FRPP heads, I would save a while longer and get the AFR's. The 165's are decent, and if you need more, get the 185's.
Originally Posted by rotarykidd
maybe i just like rainbows and puke, who says it has to be a gay thing?
Old Nov 17, 2008 | 11:23 AM
Duceanahalf's Avatar
is doing your girlfriend
Just get a set of Yates SC-1 heads.
Old Nov 17, 2008 | 12:54 PM
GNs-r-slow's Avatar
Bondsman
Then send them out to get them closed up some
Old Nov 17, 2008 | 06:47 PM
Tiffiny's Avatar
btw < went high 11 sec passes na. with ported e6 heads and a carb
Old Nov 17, 2008 | 06:52 PM
GNs-r-slow's Avatar
Bondsman
It was the carb!!!
Old Nov 17, 2008 | 08:21 PM
  #17 (permalink)
Tiffiny's Avatar
carb ftw
Old Nov 17, 2008 | 08:55 PM
  #18 (permalink)
Stealth Mode's Avatar
Still CREEPIN
so noones a fan of brodix here?
TurboRAM Member #5
24psi & Stable
GET SOME
