2011 Challenger SRT Suspension Noise
Old Mar 16, 2026 | 11:48 AM
Default 2011 Challenger SRT Suspension Noise
chrys7 Discussion starter,,,
754 posts · Joined 2011 #1 · 4d ago I replaced the following..... ignore the Charger picture . I am still hearing a thumping noise when the car goes over speed bumps . What else do I need to replace?chrys7 Discussion starter
754 posts · Joined 2011 #1 · 4d ago I replaced the following ignore the Charger [img alt=""]data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7[/img]. I am still hearing a thumping noise when the car goes over speed bumps . What else do I need to replace?
Tread Tire Care Carbon fibers Synthetic rubber
Stay Thirsty My Friends
4,204 posts · Joined 2022 #2 · 4d ago Are you sure your engine mounts are in good shape?
Stay Thirsty My Friendshunttriumph1500
2,599 posts · Joined 2010 #3 · 3d ago Many years ago, I had a weird noise on a 2009 SRT8, at low speed it sounded like rope being pulled tightly over a wooden beam, -strained. Turned out to be a busted cradle bushing in the rear (one out of the four).
owns 2011 Dodge Challenger SRT8 2008 HO- 1st Edition SRT8
2011 DWB- Inaugural Edition 392 SRT8
2012 SY- Yellow Jacket 392 SRT8
2023 B5- Charger AWD & 17 Previous Challengers!!!
  • [img alt="Like"]data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7[/img]
Interceptor496 posts · Joined 2024 #4 · 3d ago Check all bushings on stabilizers and links
Burn rubber Kermit
troyus
583 posts · Joined 2011 #5 · 2d ago Magnetic inspection light stuck in wheel well after servicing. Not saying I have ever done this... but... maybe? [img alt=""]data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7[/img]
In all seriousness, sway and end link bushes... but also the upper control arm, especially if you have some miles on them.
RollingRob392
2 posts · Joined 2025 #6 · 2h ago Are you sure it's the suspension? My 2014 SRT8 makes noise going over bumps, but it's the rear quarter panels at the bottom. They're not really attached to anything and they flap, kind of, making a thumping noise. It's very annoying
jpw65
32 posts · Joined 2023 #7 · 25m ago The sway bar end links can make some weird noises, almost sounds like a bad upper strut mount sometimes or a rattle noise, depending on how bad they are.
Feb 26, 2026 08:43 PM
American Iron Tech
Mar 31, 2018 04:50 AM
h0ndab0yb3b0
Dec 22, 2009 08:40 AM
04snake
Mar 1, 2007 05:01 PM
nismo
Dec 16, 2005 06:43 AM
