Cranking the engine to get oil circulating without starting the engine
Old Mar 20, 2019 | 08:25 AM
Default Cranking the engine to get oil circulating without starting the engine
Charge up the Battery.
Pull Fuse # 21 in rear power distribution center (fuel pump)
crank car for 3 seconds and stop. Do this 3 times.
Put #21 back in the distribution center
Start car.
This pumps oil into the upper parts without starting up and gives lubrication through the engine before it starts.
Regards,
Brian
Old Mar 20, 2019 | 08:26 AM
SVRSRTCDN
Senior Member
Join Date: Feb 2007Posts: 1,266Feedback Score: 0 reviews
You don't have to pull any fuses. To no start crank, press the brake, press the gas pedal to the floor and hold it there.
Press the stop start button and the engine will crank for 10 seconds to pump oil to the engine without starting.
Start normally after that.
Be sure your battery is fully charged
American Iron Tech
Mar 8, 2019 02:48 AM
Mazda Tech
Dec 14, 2018 01:38 PM
Drag Racing
Sep 21, 2018 05:18 AM
American Iron Tech
Jul 12, 2018 07:01 PM
Drag Racing
May 26, 2018 04:48 AM
