16 SRT alignment 2016 Charger SRT that I bought new
16 SRT alignmentHey all,
I have a 2016 Charger SRT that I bought new. From the beginning it always had a pull to the right. I hate going to the dealer so I just kept doing my thing. It has gotten worse over time and now (I have 7k miles on it) I got really annoyed and took it to a shop (That used to be a dodge dealer) to have the alignment done. Long story short they cant get the alignment to come into spec. The adjusted it to drive straight but said it will start chewing tires. They also said nothing is visibly wrong or bent, they just can't get the car in alignment.
Has anyone had a similar issue? How did you deal with it? How was dodge in trying to get it fixed?
I live in Maryland if it makes a difference.
Why not take it to a dealer to at least get the problem put on your service record? You may be out of luck with the lemon law in Maryland if you wait to long:
"Maryland's Lemon Law applies to new or leased motor vehicles (including cars, light trucks and motorcycles), registered in Maryland, that are less than 24 months old and have been driven less than 18,000 miles."
The engine cradle is probably not correctly lined up with the body. I know a guy with a Challenger that had this problem. He had it aligned three times at Larry Miller Dodge and they couldn't fix it. They got with the factory and were told to loosen the bolts that hold the engine/suspension cradle to the body an re-align it, then do the wheel alignment. Apparently the cradle was out of alignment by just a bit over 1/8" and that was throwing everything off.
Anyway, it is worth having them check this out before you try to Lemon law it.
I had a customer with a 2006 Magnum SRT8 that was eating tires on the driver side. They got with Chrysler and unbolted the front frame. Got the frame back to where it should be and now he doesn't eat tires any longer. You probably have the same thing. Have them realign the front cradle/frame and then it will be adjustable.
Regards,
Brian
BND Automotive LLC
440-821-9040
www.bndautomotive.com
Forum Vendor for 9 years!
Regards,
Brian
BND Automotive LLC
440-821-9040
For what it's worth, I'm on my second SRT. The first one saw a lot of track duty and never came out of alignment, even after taking many berms at speeds that would freak your girlfriend or mother out. Tires wore evenly even under extreme abuse. Factory alignment is pretty decent.
Generally speaking the folks at Dodge/SRT have been outstanding too me. I understand you're upset but let's be real, it don't qualify for a lemon law and I'm fairly certain it's fixable.
Remember, be nice, be patient and never throw stupid stuff around like 'lemon law' unless you actually understand what that means. Cause if you're going to spend the money to do that I bet you could drop $300 to a shop of your choose to do the work yourself.
Free oil change! OMG such a hardship...
Regards,
Brian
BND Automotive LLC
440-821-9040
Regards,
Brian
BND Automotive LLC
440-821-9040
Feb 9, 2020 07:30 PM
VW/Audi/Porsche Tech
4
Aug 7, 2016 01:44 PM
WhiteNgold
Nissan Builds and Projects
7
Jul 14, 2011 09:28 AM
