PT Super Cruiser
Originally posted by "FearThe4Doors"
i just read or heard somewhere about the PT Turbo.. dont they run about 13 or 14 psi stock?
If thats the case, I can see the grainger working since hes really not changing the boost, just having it come on quicker
no mr i beleive DCX blindly like Maurice the computer dictates what boost level to achieve the "factory" HP/TQ curves which can vary depending on variables such as weather and what not. Basically the way DCX is ensuring every 2.4 Turbo car performs to its max no matter where it is at geographically is by letting the computer do the thinking as to how much boost when and to vary things according to the variables it reads...undertand? so 7-8psi is what this PT Turbo is seeing in cold weather up in Wisconsin not saying that an FL car should and is in the double digit boost but keep in mind the variables.....
Guest
Posts: n/a
dude, say what you want, but here it is in print from a crediable source...
http://www.caranddriver.com/xp/Caranddriver/roadtests/2002/october/200210_shorttake_ptturbo.xml
And that means very well your friend could be getting 15-ish pounds of boost, since thats the factory level. It may peak a little since its getting there so much quicker
With its wee little turbine spinning 14 pounds of boost, the dyno dials churn to 215 horsepower at 5000 rpm and 245 pound-feet at 3600 rpm—a gain of 65 horsepower and 83 pound-feet.
What you are telling me is someone bled the boost 1psi over the max computer controlled boost setting. Its very viable that the computer allows this to pass as a margin of error.
So at the moment I believe DCX, for they designed the car, they know what its capable of. You have to realize I am not saying they are always correct, that would be blind faith, but what I am saying is currently they have the most knowledge of this engine and design. Consequently their statements hold more water for the time being.
Patrick
05 SRT-4: Daily Driver, 11.9@117.4
88 Aries: 2.2L Turbo (Powered by Megasquirt II)
Patrick
