We NEED an Official
Old Sep 2, 2002 | 08:02 PM
  #31 (permalink)
CrazyMoparGirl's Avatar
Guest
I love this thing soo much I dont know why, too bad its 27k
Old Sep 2, 2002 | 08:03 PM
  #32 (permalink)
Guest
oooohhh
  #33 (permalink)
Guest
aahhhhhhh
Old Sep 2, 2002 | 08:05 PM
  #34 (permalink)
Guest
Some Specs
2002 Jeep® Liberty Renegade Preliminary Specifications
[measurements in inches (millimeters) unless otherwise noted]
Engine - 3.7-liter PowerTech™ V-6
Transmission - 45RFE Automatic, NV3550 Manual
Transfer Case - NV231 Command Trac® NV242 Selec Trac®
Axle - 3.73 ratio (3.7-liter engine)
Wheelbase - 104.3 (2650)
Overall Length (including spare tire) - 175 (4445)
Overall Width - 71.6 (1819)
Height - 72.5 (1841.5)
Track (front/rear) - 60.0 (1524) / 59.7 (1516)
Running Ground Clearance - 9.7 (247)
Approach Angle - 37.8 degrees
Ramp Breakover Angle - 21.8 degrees
Departure Angle - 32.1 degrees
Headroom (front/rear) - 40.7 (1035) / 42.1 (1069)
Legroom (front/rear) - 40.8 (1036) / 37.2 (946)
Cargo Volume:
Rear seat up 29 cu. ft. (821 L)
Rear seat folded 69 cu. ft. (1953 L)
Total Volume:
Rear seat up 132.7 cu. ft. (3758 L)
Rear seat folded 121.7 cu. ft. (3444 L)
Curb Weight - 4003 lbs. (1817 kg) (3.7-L 2WD), 4251 lbs. (1930 kg) (3.7-L 4WD)
Assembly Plant - Toledo North Assembly Plant: Toledo, Ohio
Old Sep 2, 2002 | 08:09 PM
  #35 (permalink)
mpbiv's Avatar
Rod Bearing Eater
I'll take a good ole 4.0L to that cheesy 3.7 anyday
Patrick
05 SRT-4: Daily Driver, 11.9@117.4
88 Aries: 2.2L Turbo (Powered by Megasquirt II)
Old Sep 2, 2002 | 08:19 PM
  #36 (permalink)
Guest
well a welder can fix that prob
