T1->T2
Old Aug 31, 2002 | 09:33 AM
mpbiv's Avatar
Rod Bearing Eater
89 computer is a SBEC so it won't just plug into the GLH if it has 85 wiring harness becuase it uses a logic module. You'll need a logic module from like a TII GLHS I think.
Patrick
05 SRT-4: Daily Driver, 11.9@117.4
88 Aries: 2.2L Turbo (Powered by Megasquirt II)
Old Aug 31, 2002 | 10:27 AM
whore's Avatar
might as well keep the 85 in. Both are 2.2s. The 89 T2 has the charge temp sensor, but its not impt. And unless you manually run a wire from the sensor to the ECU (since the 85 harness wont have that plug), you'll have a check engine light to stare at.
And yes, you'd need an 89 Omni harness b/c it's SMEC like moreRICE said. I just woke up so im not thinking. But if you get an 89 omni harness, it wont be turbo so some things might be off there. I'd just use the old one since you'll be doing fuel and boost manually anyway probably
Old Aug 31, 2002 | 10:45 AM
4sfed 4's Avatar
4SFED4
Default Re: T1->T2
Originally posted by "rb70383"
Can any T2 computer be used in the conversion? Like a 89 Daytona Shelby 'puter, in say an 85 GLH?
Id try to find a GLHS Stage 2 logic module. (4SFED has this in him!)
That way, you wont have to change any wiring and can use the same power module. The 89 will require wiring changes and a switch to the SMEC setup.
Old Aug 31, 2002 | 07:20 PM
leadfootedfool's Avatar
Eat soot
did somebody say neon??
Eat soot
anybody??
Old Aug 31, 2002 | 07:27 PM
whore's Avatar
no
Old Aug 31, 2002 | 08:34 PM
Eat soot
well fine then...
Eat soot
i'll just sit in the corner and talk to myself....
Old Aug 31, 2002 | 08:35 PM
Eat soot
or play with myself.....either way....
